kz 250 oil filter where is it?
- alteran
07 Jun 2006 12:34
I don't have a manual for this 1980 kz250 I just bought. I have a new oil filter element but don't know what cover to remove to access the filter on the bike.
Cam someone help?
And would anyone know the oil capacity?
Thanks!
Post edited by: alteran, at: 2006/06/07 16:02
Cam someone help?
Thanks!
- jbw7300
- you can't ride if your fried
Re: kz 250 oil filter where is it?
07 Jun 2006 12:49
just a guess but is there a round plate with a bolt in the center under the bike near the drain plug??
84 kz 700 a1 sports
- OKC_Kent
07 Jun 2006 13:31
alteran,
go to the Kawasaki web site, www.buykawasaki.com and under 'owner info' you can link to parts diagrams for your machine. It's a snap to do. I printed out diagrams and made a booklet to help when I work on my bike. You'll find your filter.
The oil qty is probably between 3-4 qts. Your bike should have a way to check the level, like a sightglass window on the lower right side of the engine? Add a couple qts and let it settle, then fill the rest up to the middle of the window.
Cashion, OK
78 KZ650 B2 85,000+ miles
- TwoCam
08 Jun 2006 18:51
It's inside the engine, you get to it by removing the right side engine cover.
I can scan some pics. if you need them.
