- Thank you received: 83
Stator rotor bolt
- Powerstroke_fan
01 Jun 2012 22:52 #526355
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Stator rotor bolt was created by Powerstroke_fan
Is all kz1000 stator rotor bolts reverse thread?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Powerstroke_fan
01 Jun 2012 23:38 #526362
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Replied by Powerstroke_fan on topic Stator rotor bolt
Anyone know???
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- wireman
- Thank you received: 299
01 Jun 2012 23:47 #526364
by wireman
Replied by wireman on topic Stator rotor bolt
check your pm box,i just noticed this post.
- Powerstroke_fan
02 Jun 2012 07:31 #526419
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Thanks wireman i appreciate it.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- wireman
02 Jun 2012 13:07 #526443
by wireman
did you get it off?
- Powerstroke_fan
02 Jun 2012 18:40 #526472
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
ya i got it off thanks.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
