- Thank you received: 36
652 or 0.652 KZ650?
- faffi
01 Jun 2012 04:15 #526255
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
652 or 0.652 KZ650? was created by faffi
Hi!
I have two 650s first registered in 1977; one Euro version Z650 and one US version KZ650. The Euro bike should be a B1, the USA bike a B2 according to the frame numbers. Yet the only major differences are the fork and brake up front, other than that my B2 appears to be B1 spec.
However, one peculiar difference between the two bikes regard the cylinder block. On the Euro bike, it says 0.652 l (for litre) and on the US bike it says 652 cc. Does anyone else have 0.652 l cast into their cylinder block?
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- T_Dub
- Thank you received: 25
01 Jun 2012 06:37 #526259
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic 652 or 0.652 KZ650?
Mine says 0.652l, or it did when I still had a KZ650 block on it haha.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- RonKZ650
- Thank you received: 240
01 Jun 2012 11:58 - 02 Jun 2012 00:00 #526280
by RonKZ650
Replied by RonKZ650 on topic 652 or 0.652 KZ650?
I looked through 15 KZ650s I got sitting around. What I found was 8 said 650cc, and 7 said .752L. What I gather is all 79s say .752L, late 78s say .752L, early 78 and 77 say 652cc. The most important thing I found out of all this is I own too many motorcycles. :laugh: Edit- of course 7 say .652L, not .752L. Don't know where the 7 came in my head from.
Last edit: 02 Jun 2012 00:00 by RonKZ650.
- loudhvx
- Thank you received: 1616
01 Jun 2012 12:04 #526281
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic 652 or 0.652 KZ650?
The biggest difference in the motor will be the charging system. If the motor has 3 screws in a triangle patern on the laternator cover, then it is the 1977 type motor with the excited-field alternator.
1981 KZ550 D1 gpz.
Other links.
- Thank you received: 2829
01 Jun 2012 12:10 - 01 Jun 2012 12:10 #526283
by 650ed
Replied by 650ed on topic 652 or 0.652 KZ650?
Faffi - does the alternator cover on the bike marked 0.652 l look like the one below (with the 3 Allen screws)? If not, it is not a 1977 engine.
Attachment 1977GeneratorCover.jpg not found
Last edit: 01 Jun 2012 12:10 by 650ed.
- faffi
01 Jun 2012 18:56 #526314
by faffi
1977 KZ650B1
1980 F1 engine
B1 Points ignition
Replied by faffi on topic 652 or 0.652 KZ650?
Ed, they both have the same cover as your bike.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- faffi
01 Jun 2012 20:01 #526325
by faffi
Pity you're not my neighbour :whistle:
1977 KZ650B1
1980 F1 engine
B1 Points ignition
RonKZ650 wrote: I looked through 15 KZ650s I got sitting around. What I found was 8 said 650cc, and 7 said .752L. What I gather is all 79s say .752L, late 78s say .752L, early 78 and 77 say 652cc. The most important thing I found out of all this is I own too many motorcycles. :laugh:
1977 KZ650B1
1980 F1 engine
B1 Points ignition
