In the shim
  • lemo32
  • Topic Author
  • The Price of Cool aint cheap
31 May 2012 20:40 #526182 by lemo32
In the shim was created by lemo32
Well I got my motor back together, I have zero valve clearance, I have around 270 size shims so could somebody give me a starting point what size to start with, did a compression test had very little, so did leakdown and all valves are leaking in closed position.
1979 kz 1000 06 katana 750
  • 4TheKZ1000
  • Visitor
31 May 2012 20:45 #526184 by 4TheKZ1000
Replied by 4TheKZ1000 on topic In the shim
did you replace the valves
  • lemo32
  • Topic Author
31 May 2012 21:01 #526185 by lemo32
Replied by lemo32 on topic In the shim
no just lapped em a bit
  • 4TheKZ1000
  • Visitor
31 May 2012 21:09 #526187 by 4TheKZ1000
and you didnt have this prob before? did the valves ever leave the head, if so,,,,did they go into the orignal valve guide they came out of.
  • lemo32
  • Topic Author
31 May 2012 21:21 #526188 by lemo32
yes they were replaced in the same guide.
  • lemo32
  • Topic Author
31 May 2012 21:22 #526189 by lemo32
got 270 shims and around 280 what size? should I start with, anybodys guess would be cool :pinch:
31 May 2012 21:38 #526191 by Roadflyer
Replied by Roadflyer on topic In the shim
I would try some 255's
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
  • lemo32
  • Topic Author
31 May 2012 21:51 #526193 by lemo32
thats about what I was thinking, 240, around there thanks
31 May 2012 22:07 - 31 May 2012 22:13 #526198 by bountyhunter
Replied by bountyhunter on topic In the shim
No eBay APP ID and/or Cert ID defined in Kunena configurationYou can get a shim kit, depends on whether your time is more valuable.
Z1 also sells 20 piece shim sets.
www.z1enterprises.com/Valve-Shim-Kit--29mm-256.aspx
The 34 piece kit on top is a better deal.
Last edit: 31 May 2012 22:13 by bountyhunter.
01 Jun 2012 08:04 #526264 by Powerstroke_fan
Replied by Powerstroke_fan on topic In the shim
I think the general rule is if you can spin the shim with your finger drop one size if not start with dropping to sizes.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
01 Jun 2012 08:53 #526265 by Old Man Rock
Replied by Old Man Rock on topic In the shim
"leakdown and all valves are leaking"...
With this in mind, with the others 250/255 to start with...
And don't even bother with spining the crank, just remove the camshafts and replacing ALL the shims.
Don't want to bend a valve....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
01 Jun 2012 21:22 #526339 by APE Jay
Replied by APE Jay on topic In the shim
Put some 200s in it and see how loose that makes it, then do the math.
