- Thank you received: 2
In the shim
- lemo32
- The Price of Cool aint cheap
31 May 2012 20:40 #526182
by lemo32
1979 kz 1000 06 katana 750
In the shim was created by lemo32
Well I got my motor back together, I have zero valve clearance, I have around 270 size shims so could somebody give me a starting point what size to start with, did a compression test had very little, so did leakdown and all valves are leaking in closed position.
- 4TheKZ1000
- Visitor
31 May 2012 20:45 #526184
by 4TheKZ1000
Replied by 4TheKZ1000 on topic In the shim
did you replace the valves
- lemo32
- 4TheKZ1000
- Visitor
31 May 2012 21:09 #526187
by 4TheKZ1000
and you didnt have this prob before? did the valves ever leave the head, if so,,,,did they go into the orignal valve guide they came out of.
- lemo32
31 May 2012 21:21 #526188
by lemo32
Replied by lemo32 on topic In the shim
yes they were replaced in the same guide.
- lemo32
31 May 2012 21:22 #526189
by lemo32
got 270 shims and around 280 what size? should I start with, anybodys guess would be cool :pinch:
- Roadflyer
- Thank you received: 13
31 May 2012 21:38 #526191
by Roadflyer
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
Replied by Roadflyer on topic In the shim
I would try some 255's
- lemo32
31 May 2012 21:51 #526193
by lemo32
thats about what I was thinking, 240, around there thanks
- bountyhunter
- Thank you received: 337
31 May 2012 22:07 - 31 May 2012 22:13 #526198
by bountyhunter
Replied by bountyhunter on topic In the shim
No eBay APP ID and/or Cert ID defined in Kunena configurationYou can get a shim kit, depends on whether your time is more valuable.
Z1 also sells 20 piece shim sets.
www.z1enterprises.com/Valve-Shim-Kit--29mm-256.aspx
The 34 piece kit on top is a better deal.
Last edit: 31 May 2012 22:13 by bountyhunter.
- Powerstroke_fan
- Thank you received: 83
01 Jun 2012 08:04 #526264
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic In the shim
I think the general rule is if you can spin the shim with your finger drop one size if not start with dropping to sizes.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Old Man Rock
- Thank you received: 225
01 Jun 2012 08:53 #526265
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic In the shim
"leakdown and all valves are leaking"...
With this in mind, with the others 250/255 to start with...
And don't even bother with spining the crank, just remove the camshafts and replacing ALL the shims.
Don't want to bend a valve....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- APE Jay
- Banned
- Thank you received: 58
01 Jun 2012 21:22 #526339
by APE Jay
Replied by APE Jay on topic In the shim
Put some 200s in it and see how loose that makes it, then do the math.
