Need to adjust valves. How?
- old_skool_77
- Woot Woot
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
- Thank you received: 2098
old_skool_77 wrote: I have a 1980 kz1000 ltd b. I got some pinging noise coming from the engine when I get on the throttle but nothin at idle or cruising speed. Have been told this may be a valve not closing properly. Don't know exactly how to adjust the valves but I am mechanically able to do so. Any input on how and if I should try this at home or should I have it done by a pro? Also have open kerker and pod filters and accel ignition and coils. I don't if I should put the baffling back in the pipe or is it ok to run without. Don't know if any of this would affect the overall performance of the engine over time. Maybe this is why I havin a valve issue? Any insight to my delima will be greatly appreciated! Thanks
Per FSM, would suspect : ignition timing; spark plug gap or heat range; fuel quality; carbon build-up; fuel/air mixture; air leak; fuel level; main jet .
