engine bogs on starting off in 1st gear, why?
- AnOldRyder
30 May 2012 23:26 #526003
by AnOldRyder
engine bogs on starting off in 1st gear, why? was created by AnOldRyder
Hi Guys.. I'm sure this has been discussed before.
78 KZ650C2. after engine is warmed up, when at a stop, when I pull away, the engine rpm seems to go flat, sometimes if I don't throttle up enough, it will die. When I crack the throttle while in neutral, I seem to detect a flat spot, before it revs up. I don't know much about the carbs (which are original, just rebuilt at dealer), but it seems like what occurs when a carb accelerator pump is not working properly. Maybe someone can direct me towards some relevant threads.
- Thank you received: 2829
31 May 2012 00:47 #526026
by 650ed
Replied by 650ed on topic engine bogs on starting off in 1st gear, why?
What are you using for air filtration?
- wireman
- Thank you received: 299
31 May 2012 00:58 #526028
by wireman
Replied by wireman on topic engine bogs on starting off in 1st gear, why?
throw a can of sea foam in the tank
- AnOldRyder
31 May 2012 11:14 #526093
by AnOldRyder
Replied by AnOldRyder on topic engine bogs on starting off in 1st gear, why?
bike has 16k on it - all original
stock air box - new filter
carbs 'rebuilt' at kawai dealer (K&L parts kits)
gas tank clean as a whistle - fresh 91 octane
when I open the throttle it goes flat for just a sec, before taking off.
Actually, a bit of a drop in rpm, so when engaging clutch, it easily wants to stall her out. If I rev it up an couple of times at the stop before engaging, I can prevent the bog out, but it's likely because rpms are higher. idle rpm 1200 some times looks like almost 15. On a few occasions, when I've come to a stop, after a bit, it will slowly drop down to the point where it has quit.
- Thank you received: 2098
31 May 2012 12:04 - 31 May 2012 12:06 #526100
by Patton
Replied by Patton on topic engine bogs on starting off in 1st gear, why?
Would assure valve clearances within specs.
And sync carbs with engine running.
Pilot screws will be adjusted incident to sync and idle adjusting.
It stalling at pull-away persists, would clean carb pilot circuits.
And assure correct fuel levels via clear tube testing.
"Rebuilt" carbs might be only parts replacement, and might not include thoroughly cleaning pilot circuits and verifying correct fuel level.
Last edit: 31 May 2012 12:06 by Patton.
- mark1122
- Keep twisting it
- Thank you received: 109
31 May 2012 14:13 #526117
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic engine bogs on starting off in 1st gear, why?
just because the carbs were clearned, does not mean they are clean. it is common to have to reclean them.
u have a lean symptom. Could be dirty carbs, air leak?
i would follow Pattons recomedations.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
