Should I rebuild the tranny on my new KZ1000P?
- markplease
30 May 2012 13:48 #525879
by markplease
Should I rebuild the tranny on my new KZ1000P? was created by markplease
I just bought a year 2000 KZ1000P with 39,000 miles on it for 2500 bucks. It needs a new clutch and the transmission needs to be looked at. Should I take into a shop for an initial diagnosis? Or, should I buy a manual and start wrenching on this thing myself? If so, what is the best manual to buy? Thanks
- TomW
- Keep the blue side up.
- Thank you received: 52
30 May 2012 14:27 #525886
by TomW
The clutch is easy. The engine needs to come out to do the transmission. A lift or a 2' or so high table to put the bike on and a method to get it up there will make the job a lot easier than working on the floor with the bike on the center stand. A place inside is pretty much a must also. What are the symptoms in the clutch and tranny? Maybe just need some adjustments. Good luck and have fun.
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
Replied by TomW on topic Should I rebuild the tranny on my new KZ1000P?
Forget the dealers. Maybe an independent shop if you have a lot of money. My M.O. is buy the factory service manual and dig into it. These motors are pretty simple as motors go and there is all the help in the world right here. If you have done any wrenching successfully in the past you should have little trouble. You'll need tools. The usual wrenches, screw drivers, hammers etc. plus some measuring tools. 1"-3" outside micrometers, dial or digital vernier calipers, bore gauge or telescoping gauges if you do cylinder work and the knowledge to use them.markplease wrote: I just bought a year 2000 KZ1000P with 39,000 miles on it for 2500 bucks. It needs a new clutch and the transmission needs to be looked at. Should I take into a shop for an initial diagnosis? Or, should I buy a manual and start wrenching on this thing myself? If so, what is the best manual to buy? Thanks
- markplease
30 May 2012 14:49 #525892
by markplease
Replied by markplease on topic Should I rebuild the tranny on my new KZ1000P?
The clutch slipps when you roll back on the throttle, the motor revs up, giving it the sound like if it were a centrifugal clutch. The transmission doesn't want to shift into second, it hangs up in neutral, so it takes me several tries shifting from 1st to 2nd before it actually engages in 2nd gear. There is also an oil leak coming from the top end of the motor when it's running.
- lushbaugh
- everybodys a pro......
- Thank you received: 35
30 May 2012 15:43 #525901
by lushbaugh
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
Replied by lushbaugh on topic Should I rebuild the tranny on my new KZ1000P?
try replacing your clutch and adjusting the clutch first, if it only fixes the slip than your not out anything. i bet its just out of adjustment and when you replace the oil make sure you use oil without friction modifiers., chris
- Powerstroke_fan
- Thank you received: 83
30 May 2012 19:51 #525952
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Should I rebuild the tranny on my new KZ1000P?
If the clutch is not fully disengaging than it will make it harder to shift. Try adjusting the clutch by the manual before buying a new one. You might not need a new clutch. Its worth a shot
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
