KZ900 Valve adjustment shim question.
- KZJOE900
- Admin
Cyl___Intake__|_Exhaust
1_____< .038__|__.076
2______ .076__|__.064
3______ .058__|__.102
4_____< .038__|__.076
So the number 1 and 4 intakes are out of spec. The smallest gauge I have is .038mm (.0015 in). So there seems to be no clearance at all in these two intake valves (1,4). I have taken out the number one cylinder intake shim so far and it is a 2.55mm. My question is, should I go with a 2.45mm to increase the clearance by .10mm, or should I go with a 2.50mm for a .05mm clearance? Would just like to get some opinions before ordering the shims. I don't want to play around with swapping with any of the others shims on the bike. Not worth the time for the price of these things considering all the rest are within spec.
Joe
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- LarryC
Personally, I set the valves at max loose with the lobe straight away. .006"
Larry C.
- bountyhunter
- Thank you received: 337
If you have some so tight the lifter won't mode, assume it's zero. If it spins freely, probably between zero and .001".
- KZJOE900
- Admin
LarryC wrote: If you can spin the buckets, you can get away with 1 shim size. If not, go at least 2 sizes down.
bountyhunter wrote: If choosing between shims, I always go for the wider (in spec) value, not the tighter one. A shade loose won't hurt, a shade tight can ruin a head.
OK, I went back and checked both the 1 and 4 intakes, The buckets do spin on both so there is some clearance. So Cyl. 1 intake has 2.55 mm shim with less than .038mm (.0015") clearance. And Cyl. 4 intake has 2.40 mm shim with less than .038mm (.0015") clearance. So from what I gather you are both telling me is that it would be OK if I go down two sizes by .10mm (.004") to 2.45mm and 2.30mm shims respectively. Is that correct? That means I would end somewhere between a .004" to .0055" clearance. My service manual indicates my bike should be between .002" and .004". Larry, you said you like going up to .006";which sounds good. Does that apply to the KZ900 as well? If so, does it add much valve noise?
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Old Man Rock
- Thank you received: 225
As provided to me, due to exhaust running hotter...
Exhaust .10mm - .15mmm
Intake .05mm - .10mm
Basically as Larry taught me, if you run into a shim/clearance measurement that's border line, go loose versus tight on the clearances...
Example for an intake, let's say you measured .06mm, still in spec right...
But knowing this clearance is shrinking on you, better go with a thinner shim size and be at .11mm.
Also, measure your shims, don't just go off their stamping especially on used shims... You'll be surprise on how due to wear, they vary in actual thickness... I've run into this many times where next size (.05mm) placed me above spec by stamping but in measuring found it was slightly thinner....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- KZJOE900
- Admin
Old Man Rock wrote: KZ900 spec is as .05 - .1mm for intake & exhaust...
OMR
Thanks OMR, that's a great point you bring up about the actual vs. stamped spec on the old shims. I will measure them before ordering. In which case, if they are truly thinner than stamped, it would make my going thinner by two sizes even more OK. Thanks guys, all great info!
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- bountyhunter
My KZ750 manual says .002 - .004", but I have read it was opened up to .006" high end. I shoot for .003 - .005 but .006 does not worry me. Worst it could do is maybe click a little.KZJOE900 wrote: My service manual indicates my bike should be between .002" and .004". Larry, you said you like going up to .006";which sounds good. Does that apply to the KZ900 as well? If so, does it add much valve noise?
