- Thank you received: 2098
Ignition
- 4TheKZ1000
- Visitor
29 May 2012 00:40 #525555
by 4TheKZ1000
Ignition was created by 4TheKZ1000
do kz 1000 have a single or dual fire ignition.
Thanks, Spencer
Thanks, Spencer
29 May 2012 01:03 #525562
by Patton
Replied by Patton on topic Ignition
The coil "charges" while its primary winding is grounded through the signal wire.
Becoming ungrounded is the event that causes the coil to "fire" through its secondary loop.
- MFolks
- Thank you received: 540
29 May 2012 01:14 #525565
by MFolks
Replied by MFolks on topic Ignition
Yep, fires two (2) sparkplugs at the same time, but one will be on the exhaust stroke. If you want a multi fire ignition, look at MSD:
www.msdpowersports.com/mc-3.html
- MFolks
29 May 2012 01:22 #525569
by MFolks
Try this website, for some reason the link did not work:
- 4TheKZ1000
- Visitor
29 May 2012 08:58 #525608
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Ignition
the reason im asking this question is becouse im adding a electronic tach. The tach has to be set up for a single or double fire ignition. I need to know what a kz ignition is considered.
Thanks, Spencer
Thanks, Spencer
- kaw-a-holic
- Thank you received: 249
29 May 2012 09:20 #525613
by kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Replied by kaw-a-holic on topic Ignition
Set it to dual Spencer. What type of tach are you using. How is it connected? Direct connect or induction?
Jon
1977 KZ1000a1
Mesa, AZ
- 4TheKZ1000
- Visitor
29 May 2012 12:40 - 29 May 2012 12:56 #525647
by 4TheKZ1000
tach directions. If you hit control + it will enlarge the print. The wire cutting is a concern as I really dont understand it.
Last edit: 29 May 2012 12:56 by 4TheKZ1000. Reason: new pic
29 May 2012 13:49 - 29 May 2012 14:07 #525663
by Patton
For more legible instructions,
click here > www.autometer.com/productPDF/1077B.pdf
4 CYL.—Clip BROWN and
ORANGE wire loops.
Insulate with
electrical tape.
Hopefully, there is only one orange wire loop and only one brown wire loop.
I interpret the instructions to mean that neither the orange wire loop nor the brown wire loop is used for application with a 4 cylinder engine.
And the orange wire loop should be disabled by cutting its loop (with each of two freshly snipped orange wire ends being taped off).
And the brown wire loop should be disabled by cutting its loop (with each of two freshly snipped brown wire ends being taped off).
ORANGE wire loops.
Insulate with
electrical tape.
Last edit: 29 May 2012 14:07 by Patton.
- 4TheKZ1000
- Visitor
29 May 2012 14:51 - 29 May 2012 15:05 #525676
by 4TheKZ1000
I just went to Radio Shack and purchased the items I needed to make the Tach Adapter. It cost all of $3 and have it done and on the bike. The scem I used is posted below. Does it matter what coil post I use or mount the tach feed line to? The two top ones are getting the 12 volt from my yellow/red harness wire, and I have the bottom two going to the Dyna S two wires. Just thought the 12volt might mess with the tach? use the 12volt side or the dyna s side.
So, is the Kz1000 a dual pulse ignition. One fires two cyclinders 1 and 4 and 180 deg later the other coil fires two cyclinders 2 and 3. That two firings in 360 degrees right. One full rotation of the engine is two firings.....right.
Thanks for all the help guys
Last edit: 29 May 2012 15:05 by 4TheKZ1000. Reason: more info
- 4TheKZ1000
- Visitor
29 May 2012 14:57 - 29 May 2012 21:22 #525677
by 4TheKZ1000
Pic of Tach Adapter that I made.
Last edit: 29 May 2012 21:22 by 4TheKZ1000. Reason: more info
- Old Man Rock
- Thank you received: 225
29 May 2012 23:00 #525769
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Ignition
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
