- Thank you received: 2
1978 A2A getting close engine assembly
- vintagebiker
26 May 2012 20:06 #525004
by vintagebiker
If all else fails, JUMP!
1978 A2A getting close engine assembly was created by vintagebiker
Total restoration, over a year in progress, getting down to the last few weeks. Here are some pics of the engine cases after being sandblasted, cleaned with thinner,than base coat/clear coat, than assembly. I'm getting the itch big time now.
- 4TheKZ1000
- Visitor
26 May 2012 20:55 #525012
by 4TheKZ1000
Replied by 4TheKZ1000 on topic 1978 A2A getting close engine assembly
what paint did you use, looks nice.....I like the gloss black.
- vintagebiker
26 May 2012 22:37 #525039
by vintagebiker
Replied by vintagebiker on topic 1978 A2A getting close engine assembly
Sherwin Williams with a flexible additive, to stop cracking or flaking.
- grant_stl
29 May 2012 16:08 #525691
by grant_stl
83 KZ1100 Spectre, St. Louis elevation 500 ft.
K&N RU-0984 (pods)
4 into 1 Header
Pilots 40 1.5 turns out
Mains 135 (cylinders 2 and 3)
Mains 132.5 (cylinders 1 and 4)
Needles 5ix11 set on clip 2
Replied by grant_stl on topic 1978 A2A getting close engine assembly
Question for you as I am getting ready to tear into a spare engine. The pics show you spraying even the gasket surfaces, etc. How did you either keep the paint off when painting those areas and how did you keep from damaging them when sandblasing?
K&N RU-0984 (pods)
4 into 1 Header
- vintagebiker
30 May 2012 12:32 #525859
by vintagebiker
I sand blasted the cases in 3 seperate peices. By placing the gasket area down on the table and using glass beads it didn't hurt the gasket surfaces at all. The picture of my buddy Peter spraying the cases is actually him cleaning them with laquer thinner. Any oil soaked into the cases at this point is removed. We blew them off and let them dry for the night than I spent a couple hours taping every gasket surface. All the peices are painted individually.
- grant_stl
30 May 2012 23:32 #526005
by grant_stl
K&N RU-0984 (pods)
4 into 1 Header
Thanks, that clear it up for me.
K&N RU-0984 (pods)
4 into 1 Header
