Bar's Leaks products?
- ldizzle
25 May 2012 21:48 #524813
by ldizzle
Bar's Leaks products? was created by ldizzle
any one used these? Success stories or horror stories?
- Thank you received: 2098
25 May 2012 22:13 #524822
by Patton
Years ago in old rattle-trap cars, used stop-leak in radiators.
But before being able to afford a commercial product, used common household black pepper in the radiator.
Replied by Patton on topic Bar's Leaks products?
ldizzle wrote: any one used these? Success stories or horror stories?
- Powerstroke_fan
- Thank you received: 83
25 May 2012 22:21 #524824
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Bar's Leaks products?
i used it once in a radiator worked for a couple days till i could get a new one.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- rustbuckett
- Thank you received: 3
25 May 2012 22:23 #524825
by rustbuckett
82 KZ750-N1 Spectre (reviving)
88 EN450-A4L (reviving)
81 Suzuki GS450 (project)
Five Yamaha Blasters YFS200 (for the kids)
01 TT-R 125 (for youngest boy)
96 Honda Foreman 400 4X4 Old Faithful workhorse
Replied by rustbuckett on topic Bar's Leaks products?
I used their newest radiator stop-leak in my Pontiac V6 minivan. The product cost me sixty bucks for one can -- but it worked great. I was losing coolant through the engine, plus I had engine oil in my radiator. Bad news. It had a leaky intake manifold and i replaced that. Helped, but didn't fix the problem.
I bought those cheap little drop-in tablets and they didn't do anything. then I bought the BarsLeaks $30 dollar can of coolant additive, and it helped quite a bit but I still lost some fluid, and as I refilled the constant loss with just 50/50 mix I guess the BarsLeaks wasn't concentrated enough anymore, and the fluid consumption started creeping up again.
I finally decided to do one more try before selling the damn piece of junk, and saw their $60 can of stuff with Kevlar fibers in it. I poured it in (after flushing the system first) with new radiator fluid, and within 30 minutes it started working (has to get hot first to start sealing).
That was 2 years ago. Van's still working fine. I haul the kids around all winter to their hockey games and all spring and summer to track and lacrosse, van full of kids and no worries. It saved me from scrapping my minivan and I haven't had any more cooling system trouble with it.
- lushbaugh
- everybodys a pro......
- Thank you received: 35
25 May 2012 23:23 #524841
by lushbaugh
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
Replied by lushbaugh on topic Bar's Leaks products?
Its hit or miss with any of those products, they depend on leak size and pressure behind it. In a junk vehicle its fine to roll the dice but its just a clotting agent and it clogs radiators, blocks coolant passage wayd and heater cores. Imo id buy a manual and a head gasket or radiator before id use that stuff. Cause even if it works how long can you really reliegh on it. The extra cash or work is worth the peice of mind
- ldizzle
25 May 2012 23:50 #524845
by ldizzle
Replied by ldizzle on topic Bar's Leaks products?
Certainly!
I have the valve cover drip- Anyone have any luck with the oil additive?
- Thank you received: 2829
26 May 2012 00:09 - 26 May 2012 00:10 #524856
by 650ed
Replied by 650ed on topic Bar's Leaks products?
Why screw around with a band-aid? Just replace the gasket. Ed
Last edit: 26 May 2012 00:10 by 650ed.
