Shattered cover...where do I even begin?
  • Hatchet
  • Topic Author
  • It's better in the wind.
22 May 2012 22:28 #524150 by Hatchet
I'm a bit torn up over this one.
Attachment 078.JPG not found
Attachment 077.JPG not found
Finally got the bike put back together, filled the tank with new gas, gave it a kick and BANG - a few little pieces shot across the garage leaving a nice-looking hole.
The electric start did not work, so I tried the kickstarter.
Other than that, there's not much to tell.
I don't when the last time was the bike was run, but it turned over fine a couple of weeks ago.
Bikers are a rare breed.
Harley riders are a dime a dozen.
'83 KZ750 LTD K1. "Don't make me get the belt..."
  • 4TheKZ1000
  • Visitor
22 May 2012 22:40 #524154 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Shattered cover...where do I even begin?
WOW :pinch:
22 May 2012 23:03 #524161 by Patton
Replied by Patton on topic Shattered cover...where do I even begin?
Would remove the generator cover and see what's going on under there.
Looks like something came loose and was hit by the flywheel.
May be possible to use epoxy putty to temporarily repair the cover.
Good Fortune! :)
  • gd4now
  • Denco where did you go?
23 May 2012 01:31 #524198 by gd4now
Replied by gd4now on topic Shattered cover...where do I even begin?
Agree pull that cover and see what let loose. The electric starter is just above the location of the broken cover - could be when you attempted to use it something let go and was thrown into the cover and broke it out.
Once you find the cause and repair it, you may well be able to repair the cover with something link jbweld as a temp repair.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Hatchet
  • Topic Author
23 May 2012 03:42 #524204 by Hatchet
Replied by Hatchet on topic Shattered cover...where do I even begin?
Alright guys, thanks for the replies.
I managed to pull the cover with some difficulty (the screw closest to the hole was literally sheared in half atomizer-style), and take a look inside.
The first thing noticeable was that the starter chain (?) was hanging completely loose around it's sprocket, and the electric start gear was now free-spinning with no attachment to the chain. The starter sprocket itself was missing several teeth.
However apart from the electric starter I'm not sure there was a lot of damage. I pulled the chain and electric start sprocket and the rest of the motor seems to turn fine. I'm guessing that it will still run with the kicker. Which is fine, 'cause I prefer the kicker anyway.
I'll post some pictures of the inside tomorrow for further opinions. This doesn't seem to be the crisis I had anticipated, but it's just my luck anyhow. Not everyone can say they've had a hole punched through their generator cover...
