Question re: removing tachometer pinion (camshaft)
- grendel
- '82 KZ250
22 May 2012 18:19
Hiya folks ... I'm trying to install a camshaft, and part of that process is removing the tachometer pinion before the camshaft goes in...
The factory manual states that "CAUTION: Attempting to install the camshaft with the tachometer pinion left in the cylinder head may cause tachometer gear damage."
I've unscrewed the tachometer cable, and it's come free from the pinion... and I can see the pinion still inside the head, but I can't figure out how to get it out?! I've tried needle-nose pliers, pulling straight out AND trying to "unscrew" it out... neither seem to budge it. It will spin freely, and I can see it clearly if I look through where the camshaft was.
This is my first time tearing a motor apart, so I'm being gentle with it.. do I just need to be more 'manly' with it? Is there some trick to getting this thing out?
Thanks for any advice!
Bike is an '82 KZ250, btw.
1982 kz250
Re: Question re: removing tachometer pinion (camshaft)
22 May 2012 19:42 - 22 May 2012 19:42
If needed, a service manual should be available through one or both of these links:
www.kzrider.com/forum/13-bike-related/47...test-download#472613
merzymania.blogspot.com/2008/09/manual-b...nload-files-for.html
Might also find a helpful parts diagram on kawasaki.com, which includes parts diagrams, part names, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Last edit: 22 May 2012 19:42 by Patton.
- RonKZ650
22 May 2012 19:57 - 22 May 2012 19:59
You never need to remove the pinion. Don't care what the manual says. It's a complete waste of time and effort. Well on second thought I just saw it's a KZ250, so disregard. I was thinking of the larger KZ 4 cyl.
Last edit: 22 May 2012 19:59 by RonKZ650.
- grendel
- '82 KZ250
23 May 2012 02:01RonKZ650 wrote: You never need to remove the pinion. Don't care what the manual says. It's a complete waste of time and effort. Well on second thought I just saw it's a KZ250, so disregard. I was thinking of the larger KZ 4 cyl.
Sooooo, I *do* need to remove it?
Anyone?
1982 kz250
- grendel
- '82 KZ250
26 May 2012 16:56
Well, apparently, I didn't need to remove it - everything is back to normal after reassembly (as far as this piece is concerned, anyway).
1982 kz250
- Powerstroke_fan
27 May 2012 17:29
On my 1000 i just wiggled the gear back and forth to get it to mate up with the camshaft while installing cams. worked great for me.
1977 KZ 1000 work in progress
- cmuns
04 Feb 2020 17:10
Hey any advice for someone who does need to remove the pinion? I'm transferring one from one cylinder head to another and I wiggled the bolt head thing free and now it just spins freely.
Any help or direction will be appreciated!
- cmuns
04 Feb 2020 18:54
I figured it out. You just need to pull it out
04 Feb 2020 19:08
cmuns,
Nobody has posted to this thread since May 2012, and many of the posters are no longer around. In the future, you might get better responses by starting a new thread.
