NOOB Build up Questions
21 May 2012 00:40 #523720 by jdbusch
NOOB Build up Questions was created by jdbusch
ok so im planning on tearing down my 83 kz1100 to fix all the little oil leaks, and was wondering.... i really need some more power( not like a drag bike) and was wondering what kida cams / jet / pipe would be a good power mix with good streetability and cost effectiveness?
ive built up cars but never a bike. i kinda look at it like a 4 cylinder tuner engine, but still learning how to match parts and pick and choose.
any help would be awesome
Current:
1983 KZ1100-A3 Shafty
Gone:
1979 KZ1000-E Shafty
Email:
jdbusch1978@hotmail.com
  • wireman
21 May 2012 00:54 #523731 by wireman
Replied by wireman on topic NOOB Build up Questions
Before you tear it all apart run a compression test and a leak down test to get a baseline of what you have to work with.
Big cams will do you little good with out of round bores or leaking valves :)
The following user(s) said Thank You: jdbusch
