zx 12
  • Powerstroke_fan
  • Topic Author
20 May 2012 21:04 #523631 by Powerstroke_fan
zx 12 was created by Powerstroke_fan
Has anyone ever thought about or put a zx 12 or zx 14 on a kz? from what i have read these are some bad motors. Just wondering what all would go into it getting it in the frame?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
20 May 2012 21:27 #523636 by racer54
Replied by racer54 on topic zx 12
I'm sure there would be many obstacles to overcome but one of the main ones would be the frame...especially the backbone part on the KZ. Under the tank is where a ZX12-14 injectors are located along with the air cleaner. Look at the shape of a KZ tank and the shell off one of those other bikes and you can see the difference you would have to deal with. I've seen a busa motor used but that bike was using an aftermarket frame, etc....basically he just hung KZ bodywork on the busa set-up. Looked good and ran good but that would be simple compared to trying to fit a 12-14 motor into a KZ. You would basically end up with very little of original frame left. Then you have to wire in electrical system to handle the issures with the injectors, etc. And that's just the beginning.
20 May 2012 21:38 #523640 by ultimate fighter
Replied by ultimate fighter on topic zx 12
Maybe if you were to re-index it in the frame and allow it to be a stressed member.
however you'd need to change most everything on the bike, in which case you might as well start with another bike
love building motorcycles one headache at a time
21 May 2012 00:38 #523719 by steell
Replied by steell on topic zx 12
ZX12 and ZX14 motors are not stressed frame members, they hang from the backbone.
It's a major undertaking to install either one in a ZX11 frame, and the ZX11 is already liquid cooled with the forward slanting cylinder block.
Best motor for a KZ frame is the matching KZ motor :)
21 May 2012 09:06 #523783 by 650ed
Replied by 650ed on topic zx 12
Don't listen to those nay-sayers! It’s a simple, direct swap. Just follow these steps:
1. Remove the valve stem caps from the tires of the KZ
2. Hold the caps while a friend rolls the KZ forward about 20 feet
3. Have the friend then roll the ZX up to the spot that the KZ previously occupied
4. Install the caps on the ZX
That’s all there is to it; you’re ready to ride. :whistle:
And if you ever change your mind, you can easily reverse the change. ;)
  • wireman
21 May 2012 09:30 #523785 by wireman
Replied by wireman on topic zx 12
650ed wrote: Don't listen to those nay-sayers! It’s a simple, direct swap. Just follow these steps:
:woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
21 May 2012 10:54 #523803 by JEFFG1
Replied by JEFFG1 on topic zx 12
i got a friend that put a kz 1428 with turbo motor in a 1990s zx1100 frame but not vise-a-versa.slick deal :woohoo:
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
  • Powerstroke_fan
  • Topic Author
21 May 2012 15:15 #523845 by Powerstroke_fan
Replied by Powerstroke_fan on topic zx 12
Ya figured it would be a big job. i am not gonna attempt it. i was just curious. I have been looking at some other bikes but the only one i see that i like were the zx11 eddie lawson replicas. Not that the kaw is going anywhere. lol ill probally have it till i die.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
21 May 2012 16:43 #523856 by steell
ZRX1100
ZX11
Maybe you mean ZRX1100?
  • Powerstroke_fan
  • Topic Author
21 May 2012 17:35 #523863 by Powerstroke_fan
ya zrx i was in a hurry typing
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
21 May 2012 17:40 #523865 by mtbspeedfreak
Replied by mtbspeedfreak on topic zx 12
A nice REX will set you back 3-4 grand. Put that money into boring the jugs, porting the head, stump pulling cams, and match everything to a nice rack of RS carbs.
2000 ZRX 1100
1976 KZ 900- Daily Driver
21 May 2012 18:59 #523882 by LarryC
Replied by LarryC on topic zx 12
:laugh: That's so much easier
Larry C.
