kick starter popty pop pop!
  • lemo32
  • lemo32's Avatar Topic Author
  • The Price of Cool aint cheap
20 May 2012 10:03
#523517
Anybody know why my kickstarter keeps popin when the motor is turned over, this is by hand of course, kz 1000, 1979, I put the kick shaft on the stop, just like the book says and assembled it in nuetral, man this thing is driving me crazy!
1979 kz 1000 06 katana 750
  • Old Man Rock
  • Old Man Rock's Avatar
Re: kick starter popty pop pop!
20 May 2012 10:10 - 20 May 2012 10:11
#523518
Spring rotation to shaft notch reversed... ;)
It's easy to do backwards, don't ask... :blush: lol...
Correct rotation to notch in shaft...CCW
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 20 May 2012 10:11 by Old Man Rock.
  • lemo32
20 May 2012 10:35
#523520
Dont have the tension spring on the shaft yet, do I need to split cases again? kinda confusing? its like its staying engaged and might make using it hazardous lol! :
  • Old Man Rock
20 May 2012 12:28
#523537
Nope...
Rotate the shaft w/out spring by hand until it latches completely in default start position.
If I remember correctly CCW... You'll here it ratchet over the locking tabs between the shafts (internally).
Once in position, the spring holds it there otherwise it will do what your describing...
You're Ok, without the spring it will do that and you truly can't screw this portion up thus having to split the cases again... :pinch: :whistle:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Old Man Rock
20 May 2012 12:34
#523538
In case you need....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
The following user(s) said Thank You: BlackZ1R
  • lemo32
20 May 2012 14:37
#523557
Thanks OMR now I know why the call You Omr! YOU ROCK LOL! fixed that bitch, now on to more bitches! :whistle:
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
20 May 2012 14:38
#523558
Old Man Rock wrote: Nope...
Hey, OMR, good advice. What are you using to seal your cases with now?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
  • Old Man Rock
20 May 2012 15:39 - 20 May 2012 15:39
#523574
I use the 3 Bond on cases...
Copper spray on gaskets... ;)
Cam cap end plugs, slight smear... Permatex Black gasket maker to help seal...
All good... ;)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 20 May 2012 15:39 by Old Man Rock.
  • BlackZ1R
  • BlackZ1R's Avatar
25 May 2012 01:44
#524639
Yup, 1104 is the way to go. A little dab'll do ya. It's been discontinued for a while now, but I still have a good bit left in my last tube.
I hear 1194 is discontinued now....damn EPA. What's gonna happen when they ban LATEX??? :laugh:
Kawasaki
  • munkybrain2010
  • munkybrain2010's Avatar
  • Clueless..
25 May 2012 14:32
#524739
My whole wardrobe will be out of style! :ohmy: haha JK
Keep it together man!
79 KZ650 "Geto Cycle"
