oil leaking stator
- ran429
- Master of FREE rides!
oil leaking stator
05 Jun 2006 17:20
I noticed today that I have oil dripping through the stator area for some reason, I thought the stator was a dry area?
- ejshotgun
Re: oil leaking stator
05 Jun 2006 17:44
That's what I thought (on mine) until I opened it up and saw that there are a couple of gears in there that have to be oiled. The starter idler gear meshes to the starter clutch gear to crank the motor.
On mine (and I've heard from several others) were the stator wires come out of the motor is a common area to have an oil leak. The rubber grommet that the wires come through gets old and shrinks.
- 77kz700?
05 Jun 2006 18:03
I don't think you're supposed to have oil leaking out there! Time to get dirty!:blink:
- duncan
12 Jun 2006 15:31
ejshotgun wrote:
i looked at a kz1000 last autumn and the only problem was the same oil leak described here, that the vendor also said was fairly common. he suggested silicone, but here's another fix:
www.z1enterprises.com/detail.aspx?ID=373
