Order of Adjustments??
19 May 2012 20:35 #523427 by srosebrock
Order of Adjustments?? was created by srosebrock
I was going to check/adjust the float level, pilot screws, and synch the carbs. Is there a particular order I should do these things in for better results?
1982 KAWASAKI KZ440-A
20 May 2012 08:06 #523502 by LarryC
Replied by LarryC on topic Order of Adjustments??
floats, mixture screws, synch, mixture screws again
Larry C.
20 May 2012 18:35 #523608 by srosebrock
Replied by srosebrock on topic Order of Adjustments??
Thanks, also, how do I know if the mixture screws are adjusted properly other than just by how the bike sounds. It takes forever for the bike to warm up so I am trying to balance things out as much as possible.
21 May 2012 01:39 #523748 by 893cv
Replied by 893cv on topic Order of Adjustments??
You will need to check the valve clearance before you try to sync the carbs. If any of the valves are tight that will mess with the sync.
Valve clearance, floats, mixture screws, synch, mixture screws again
1980 kz1000 LTD
1978 Z1R
21 May 2012 07:40 #523765 by LarryC
Idle quality, initial throttle response, backfiring on deceleration, all those play into the pilot mixture adjustment.
As was pointed out, the valve lash adjustment should be part of the tune up. Ignition timing should be checked as well. Carb synch is the final step in a tune up.
Larry C.
21 May 2012 13:39 #523830 by srosebrock
Cool, thanks, I checked the valve and the timing already, the carb adjustments are the last thing on my list.
