Engine oil mystery
- 2bskor
Engine oil mystery
05 Jun 2006 16:51
My engine oil is milky looking sort of whitish more so after I ride, any reasons??
I changed the oil because someone said it was moisture.
When I changed the oil and filter it looked normal is it thr sight glass??
Post edited by: 2bskor, at: 2006/06/05 19:52
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
- ran429
- Master of FREE rides!
Re: Engine oil mystery
05 Jun 2006 17:19
Run a bit of seafoam or marvel mystery oil through it for 20 30 minutes to break down the oil and drain & refill.
any moisture will cause it to turn milky. this will allow it to drain easier (thinner) and get the most of it out, plus clean it while its running.
Just dont keep it in there as it thins out the oil too much and will harm the rings & bearings if ran for too long.
follow the directions & youll be fine.
- loudhvx
05 Jun 2006 17:51
As Randy said, it's probably moisture. If you just run it in some hot weather for a while, the water should boil out.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- 2bskor
05 Jun 2006 18:14
Thanks I will try to give it a good run for a few weeks if it ever stops raining:angry:
I am a little nervous of putting seafoam or anything else in the oil but perhaps before the next oil change:unsure:
