1987 kz1000 bobber Tranny problem
  • Ogcoda
  • Ogcoda's Avatar Topic Author
  • Killing Everything
18 May 2012 15:24
#523156
So, I finaly got the son of a bitch running and took her around the block. aside from the carbs needing to be re jetted it runs pretty good! But when I went to shift into second it wouldn't... All i have is 1st. Any ideas?
1978 kz1000 Bobber
2006 MazdaSpeed6
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Moderator
Re: 1987 kz1000 bobber Tranny problem
18 May 2012 15:38
#523159
Did you split the cases or do any transmission work at all ?
  • Ogcoda
18 May 2012 16:25
#523173
Street Fighter LTD wrote: Did you split the cases or do any transmission work at all ?
Nope, just took and bobbed the frame and put the engine back in...
1978 kz1000 Bobber
2006 MazdaSpeed6
  • Away
  • Moderator
  • Moderator
18 May 2012 16:29
#523174
Did trans shift before this ? Was bike rolling when you shifted as kaws wont shift up into 2nd unless rolling ( this is the positive neutral feature ).
18 May 2012 20:35 - 18 May 2012 20:37
#523223
Ogcoda wrote: ... went to shift into second it wouldn't... All i have is 1st....
If the failure to shift occurred while the bike was being ridden ---
Perhaps the shift lever is hitting against something that stops its upward motion short of effecting the gear change from 1st into 2nd.
Or perhaps the shift lever is loose on the shaft and slipping whereby the shaft isn't rotating far enough to complete the shift from 1st into 2nd. Tightening the lever might help.
Or perhaps the shift lever isn't positioned correctly on the shaft, whereby it's resting position is too high, and from there it can't go high enough to complete the shift from 1st into 2nd. Could loosen and remove the bolt, remove the lever, and replace the lever one spline lower where the lever will have more travel before reaching its upper limit of travel, and replace and re-tighten the bolt.
Good Fortune! :)
Last edit: 18 May 2012 20:37 by Patton.
