Striped drain plug
15 May 2012 20:58 #522584 by Starlifter
Striped drain plug was created by Starlifter
Can anyone out there help me! Previous owner did a number on the drain plug. Of course won't tighten. Anybody have a fix? Any thoughts to fix the problem would be greatly appreciated. Thanks
15 May 2012 21:15 #522586 by Powerstroke_fan
Replied by Powerstroke_fan on topic Striped drain plug
You could probally use a helicoil.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
15 May 2012 21:20 #522587 by 650ed
Replied by 650ed on topic Striped drain plug
Welcome aboard! It would be helpful it your put the year/model of your bike in your signature line. Many KZ's have removable oil pans, but some do not, so the repair may depend on which model you have. Ed
15 May 2012 21:29 #522589 by Starlifter
Replied by Starlifter on topic Striped drain plug
1979 kz650b
  • 4TheKZ1000
  • Visitor
15 May 2012 21:32 #522590 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Striped drain plug
if its a kz just purchase a new oil pan. can get one for 20 dollars.
15 May 2012 21:33 #522591 by Patton
Replied by Patton on topic Striped drain plug
An auto supply store such as Auto-Zone may carry an oversize self-threading oil plug.
Or it may be possible to tap the stripped hole to accommodate a larger plug.
Good Fortune! :)
15 May 2012 22:32 #522598 by 650ed
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
15 May 2012 22:43 #522599 by rathawk
Replied by rathawk on topic Striped drain plug
I had the same problem, got a whole new pan and plug on ebay for 30 bucks.
