33 smoothbore help jetting please
  • boose
  • boose's Avatar Topic Author
14 May 2012 00:54
#522203
Wondering what size jets I Gould go to? I have 33 smoothbores. Gpz head, 10 25 1 comp pistons, Andrews mild cams, k&n pods, kerker exhaust. I put 140 jets in and the plugs still looked way lean. I have to order them online so it's a guessing game for me that can get expensive. I tried drilling them but it's not to accurate! I'm up to a 3/32 drill bit an they still look lean. I think the jets go up to 240 so I dnt know where to start! Also wondering if pilot needs done! Thanks guys
  • baldy110
  • baldy110's Avatar
Re: 33 smoothbore help jetting please
14 May 2012 12:18
#522278
How does the bike run, if it runs good then leave it alone. My experience with the modern blends of gas, plug reading is getting unreliable.
14 May 2012 14:59
#522306
boose wrote: Wondering what size jets I Gould go to? I have 33 smoothbores. Gpz head, 10 25 1 comp pistons, Andrews mild cams, k&n pods, kerker exhaust. I put 140 jets in and the plugs still looked way lean. I have to order them online so it's a guessing game for me that can get expensive. I tried drilling them but it's not to accurate! I'm up to a 3/32 drill bit an they still look lean. I think the jets go up to 240 so I dnt know where to start! Also wondering if pilot needs done! Thanks guys
:unsure: What engine displacement?
33's are imo too large for most Kaw large fours.
At least with regard to tuning the full range.
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
Good Fortune! :)
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
14 May 2012 15:51 - 14 May 2012 15:53
#522314
how many cc's. i ran rich with 140's on my 1135 motor. but it ran good. dont worry about color on the plugs .with modern gas, it takes a lot more miles to get color.
time how long it takes u to increase 20mph in 4rth or 5th gear at WOT. best jets produce the best time.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 14 May 2012 15:53 by mark1122.
  • gpz1170
  • gpz1170's Avatar
16 May 2012 14:44
#522718
on an 1170 gpz motor, 132.5 main, 30 pilot and needle raised one notch
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
  • turboguzzi
  • turboguzzi's Avatar
16 May 2012 15:16
#522720
how does it run? i push my mixture towards very clean plugs in my racers.
if it stutters and overheats, cant WOT, etc. , then yes, 140 and still lean sounds odd,
maybe try raising the needles some?
drilling jets never a good idea.....
found that dell'orto makes super cheap jets with 5mm and 6mm that work well on Japanese carbs, SUDCO jet prices are a bit of a scandal
TG
