Kz440 1mm oversized piston
11 May 2012 03:34 #521475 by Just bob it
Kz440 1mm oversized piston was created by Just bob it
i am new on posting on here but i have used this form for a lot of ideas since i have been bobbing my 440 for the last 6 months and i have been stuck for the last 2 on trying to find 1mm over pistons rings... it is the only thing i am waiting for to start them engine... i hope someone can help me find rings for it... bike bandit says they have them but i tried to order then and they are discontinued... the only thing i have think of is having to special order custom piston & ring set from Wiseco... help me Plz
  • wireman
11 May 2012 03:57 #521479 by wireman
Replied by wireman on topic Kz440 1mm oversized piston
For some reason I want to say try suzuki pistons B)
  • Motor Head
11 May 2012 10:28 #521515 by Motor Head
Replied by Motor Head on topic Kz440 1mm oversized piston
Try Hasting Rings, www.hastingsmfg.com/
You will need all of the dimensions of the rings, most likely when you call them. They should have something to fit your bike.
