cam clearance
10 May 2012 20:46 #521326 by fstphil66
cam clearance was created by fstphil66
I am putting new cams in a 82 p-1 kzp,( j motor)I am bumping the intake up to .377 lift and the exhaust up to a .366 lift.I did the head over and used bigger valve springs.Will I need any more mods to the head? Thankx in advance, PhilEfq
12 May 2012 11:17 #521784 by LarryC
Replied by LarryC on topic cam clearance
fstphil66 wrote: I am putting new cams in a 82 p-1 kzp,( j motor)I am bumping the intake up to .377 lift and the exhaust up to a .366 lift.I did the head over and used bigger valve springs.Will I need any more mods to the head? Thankx in advance, PhilEfq
Those cams should not need the tappet bores clearanced.
Larry C.
