Dyna S mounting problem '84 ZN1100
10 May 2012 17:34 #521287 by bexx
Gentlemen! I want to upgrade the ignition on my '84 ZN1100. I picked up a Dyna S kit that won't fit. I emailed Dynatek and they responded with the following info: Kawasaki changed the 'pick up mounting' in '82. However, if I change the 'right side casting' to one from an earlier 'J' model it'll fit WITH a 'mechanical advancer'.
I must admit to being a total Noob in regard to these things and don't know where to look and what exactly to look for. I've looked on ebay and PowersEdge (OEM parts) to no avail.
Any help/advice/links would be greatly appreciated!
Thanks in advance!
10 May 2012 18:37 #521301 by etbike3135
Replied by etbike3135 on topic Dyna S mounting problem '84 ZN1100
Your bike has a CDI ignition and you need a ignition housing from an 81 up with a mechanical advancer. Dont know which models had the CDI but if you found and LTD or CSR 1000 housing they would work.
1973 Kawasaki Z1
18 years in dragbikes
11 May 2012 07:16 #521486 by etbike3135
No eBay APP ID and/or Cert ID defined in Kunena configurationI just searched a couple minutes and found this, im sure there is a cheaper one somewhere. The earier KZ's had a smaller seal and your need the big seal J version like this one.
1973 Kawasaki Z1
11 May 2012 11:18 #521523 by bexx
Replied by bexx on topic Dyna S mounting problem '84 ZN1100
So thats what I'm looking for in regards to 'right side casting'? A inner ignition cover? And what about the 'mechanical advancer'? Is that part of the Dyna kit or is that something seperate/stock?
  • Motor Head
11 May 2012 11:25 #521524 by Motor Head
Replied by Motor Head on topic Dyna S mounting problem '84 ZN1100
Is there a problem with your Factory Ignition? Changing out to a Dyna S and mechanical advance doesn't sound like an upgrade. Maybe the Dyna 2000 with a programmable curve would be a upgrade over the stock system.
11 May 2012 11:59 #521533 by baldy110
Replied by baldy110 on topic Dyna S mounting problem '84 ZN1100
What motor head said. The stock Kawasaki electronic ignition is very good, don't mess with it if works.
