Cam End Plugs
  • Fastdave61
  • Fastdave61's Avatar Topic Author
Cam End Plugs
07 May 2012 21:25
#520571
The cam end plugs keep blowing out of my '80 KZ 1000. Long story short, last fall I did a top end, weather was cold so I only put on 250 miles, bike ran great. This winter I removed the cam cover and adjusted the valves, installed a new gasket and cam end plugs. I added pods and vented the crankcase. First test ride, 2 plugs blew out. Installed new plugs (super glue this time) they blew out within 3 miles. Kind of hard on my Danners. Any tips regarding sealant, ect will be appreciated. Thanks in advance. FD61
1969 BSA A65F Firebird
2004 BMW R1150RT
1980 Kz1000G1
2008 Triumph Tiger 1050
Bemidji, Mn
  • Kapahulu
  • Kapahulu's Avatar
Re: Cam End Plugs
07 May 2012 21:35
#520574
2strokeworld.com
The following user(s) said Thank You: Fastdave61
  • Garn
  • Garn's Avatar
Re: Cam End Plugs
07 May 2012 21:45
#520576
FastDave, I think the answer is to....
Make sure the cam end plugs fit and don't protrude too much
Ensure the surfaces are free from oil.
Allow time for sealant to cure, before pulling the cam cover down.
I have seen the Black alloy cam plugs fitted neatly and have been thinking of going with them.
RegardZ
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Cam End Plugs
07 May 2012 22:17
#520584
Go Aluminum and no issues for 30 years
Check for restricted crankcase breather. I added a breather to my cam cover and run the vent hose to my chaingard or a catch can if dictated by race track.
  • MFolks
  • MFolks's Avatar
Re: Cam End Plugs
08 May 2012 00:27
#520629
Or, install the cam plugs so the flange in on the inside, so it can't blow out.
  • bountyhunter
  • bountyhunter's Avatar
Re: Cam End Plugs
08 May 2012 02:42 - 08 May 2012 02:46
#520645
Yamaha 3-bond, let it cure.
Clean off all the old adhesive and oil/grease.
Last edit: 08 May 2012 02:46 by bountyhunter.
  • Fastdave61
Re: Cam End Plugs
11 May 2012 22:42
#521671
Thanks Hunter: Used Yamabond, installed cover snug let sit over night, installed new gasket, seems to be fine now, hope it stays that way. Thanks again, FD61
what if the Hoke-Pokie is what its all about
2004 BMW R1150RT
1980 Kz1000G1
Bemidji, Mn
