Sufficient Break-In Mileage For Synthetic Oil???
- bountyhunter
Re: Sufficient Break-In Mileage For Synthetic Oil???
26 May 2012 17:30Me too, so I don't use syn on first run because it costs too much to run 50 miles and dump.wireman wrote: Well as many times as I change the oil after rebuilding a motor it would be really expensive/waste of money to use synthetic.
I change it after 30 minutes of running ,then again at 500 miles .
- bountyhunter
26 May 2012 17:36 - 26 May 2012 17:43I base it on the fact that some high end new cars are running full syn from day one.baldy110 wrote:bountyhunter wrote: You can switch anytime, you can run syn from the start. It's a myth that engines won't break in using synthetic oil.
Is this from personal experience? My own experience from rebuilding engines is I have never managed to get the rings to seat using synthetic oils. I end up taking the top end apart re-honing the cylinders then reassemble and break in again with conventional oils. After about doing that 3 times on 3 different engines I no longer break in using synthetic oils. I have never had a problkem breaking in rings with conventional oils.
To answer the OP's original question, yes you can switch at 1200 miles. I usually wait until I have 1000 miles on a fresh engine then switch if I want to.
Last edit: 26 May 2012 17:43 by bountyhunter.
- kaw-a-holic
26 May 2012 17:39
I use Lucas full synthetic motorcycle oil. They also have a partial synthetic if you are still on the fence about the break in period. I also use the fuel additive to keep the top end lubed. When the bikes came out we still had lead in gas which lubricated valves. It also keeps everything clean. I run Lucas in everything with a motor. Just my opinion.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- bountyhunter
26 May 2012 17:45I have also been running the Lucas fuel add "top end" stuff for about five years. It keeps the gas fresh and keeps the carbs clean. I haven't had to do any maintenance on the carbs in that time. Good stuff.kaw-a-holic wrote: I use Lucas full synthetic motorcycle oil. They also have a partial synthetic if you are still on the fence about the break in period. I also use the fuel additive to keep the top end lubed. When the bikes came out we still had lead in gas which lubricated valves. It also keeps everything clean. I run Lucas in everything with a motor. Just my opinion.
- DFIGPZ
- vintagebiker
26 May 2012 20:23
I don't recommend a full synthetic oil, Use a semi/senthetic oil, and one made just for motor cycles. Full synthetic oil can cause your clutch to slip and burn out. Automotive oil doesn't have the molecule shear additive in it like motorcycle oils have, due to the transmissions running in the same oil as the engine oil. The gears shear the oil molecules very quickly if it is not motorcycle oil.
If all else fails, JUMP!
- pig9r
27 May 2012 00:04bountyhunter wrote:I base it on the fact that some high end new cars are running full syn from day one.baldy110 wrote:bountyhunter wrote: You can switch anytime, you can run syn from the start. It's a myth that engines won't break in using synthetic oil.
Metallurgy and machining are much more advanced than 20 to 30 years ago too. I have owned a few new Triumph motorcycles. They were filled from the factory with convential oil for break in. Then at 500 miles they require a change to synthetic.
- pig9r
27 May 2012 00:08vintagebiker wrote: I don't recommend a full synthetic oil, Use a semi/senthetic oil, and one made just for motor cycles. Full synthetic oil can cause your clutch to slip and burn out. Automotive oil doesn't have the molecule shear additive in it like motorcycle oils have, due to the transmissions running in the same oil as the engine oil. The gears shear the oil molecules very quickly if it is not motorcycle oil.
This is not accurate. Using energy conserving automotive oil is said to cause clutch slippage.
I have run full syn in several wet clutch motorcycles (all done per the manufacturer's recommendations) with no problems. I would say almost all motorcycles made today the manufacturers recommend full syn; either wet or dry clutch.
27 May 2012 01:00vintagebiker wrote: I don't recommend a full synthetic oil, Use a semi/senthetic oil, and one made just for motor cycles. Full synthetic oil can cause your clutch to slip and burn out. Automotive oil doesn't have the molecule shear additive in it like motorcycle oils have, due to the transmissions running in the same oil as the engine oil. The gears shear the oil molecules very quickly if it is not motorcycle oil.
Sorry, but you need to do a little homework on full synthetic oils. Full synthetic MOTORCYCLE oils that meet the JASO-MA standards are perfect for our bikes because they are made specifically for wet clutch motorcycles. As far as the AUTOMOTIVE oils, I do not know of any currently produced synthetic, blend, or non-synthetic, oils that meet the JASO-MA standards, so I would not use them in a KZ.
For your homework assignment, please read the following link. Notice the description "Optimized wet-clutch performance - Meets JASO MA." All kidding aside, MOTORCYCLE synthetic oil works great.
www.mobiloil.com/USA-English/MotorOil/Oi...acing_4T_10W-40.aspx
- bountyhunter
27 May 2012 23:53 - 27 May 2012 23:59
For the record, it's generally not the oil which fails due to motorcycle usage, it's the additives specifically viscosity increasers (VI's) which are long polymer molecules. Running the oil through the gears in the tranny chops them up over time and your 10-40 oil gradually turns into 10W oil. Some of the better new oils have stronger VI's.
An advantage of pure synthetic oil is that it takes very little VI additive to make it track the multi grade viscosity profile, so it has less additives in it. In that regard, true syn is actually better suited for bike usage.
general oil info;
www.calsci.com/motorcycleinfo/Oils1.html
same reference as to why I doubt the "synthetic won't break in" :
general oil info;
Choosing a Break-In Oil for Your Motorcycle
The theory that synthetic oils should not be used during break in is the same as the theory that your engine will break in better if you use synthetic oil but add a dinner candle to your four quarts of engine oil. Frankly, I find this theory, um, questionable. Oh, hell, laughable. Corvettes and Porsches come from the factory with Mobil-1 in their engines. Remember, these engineers have designed world-champion engines for F1, Indy, Le Mans 24 hours, etc.
There's a lot of mythology surrounding break-in oil. It's simply not the case that synthetic oils are more "slippery" than conventional oils. Also, break-in of a modern engine is completely different than break-in of an engine made before about 1980. Modern engines, by comparison to something made in the '60s, are pretty much already broken in from the factory due to the fact that today we hold much tighter machining tolerances. The exception, of course, would be the Ural, a motorcycle made on a production line unmodified since about 1935.
Last edit: 27 May 2012 23:59 by bountyhunter.
- wireman
28 May 2012 00:00I think my head just explo9ded! :woohoo:bountyhunter wrote: For the record, it's generally not the oil which fails due to motorcycle usage, it's the additives specifically viscosity increasers (VI's) which are long polymer molecules. Running the oil through the gears in the tranny chops them up over time and your 10-40 oil gradually turns into 10W oil. Some of the better new oils have stronger VI's.
general oil info;
- pig9r
28 May 2012 01:50 - 28 May 2012 01:54bountyhunter wrote:Choosing a Break-In Oil for Your Motorcycle
This contradicts what you posted earlier about the OP using syn after a rebuild. The OP has a '79 MKII, which according to this quote should be treated differently than a modern engine.
Last edit: 28 May 2012 01:54 by pig9r.
