loose guides in J Head
- LarryC
07 May 2012 14:39 #520501
by LarryC
Larry C.
loose guides in J Head was created by LarryC
Here's an example of loose fitting J Model Valve Guides.
This is out of an E.L.R. Head. You can see how black the guide is where the oil was getting by between the guide and the guide bore. This is not uncommon in J model heads and in fact, about the 4th ELR head in particular I've run into this situation.
The bike only has 12000 miles on it but oil consumption was high. The seals were all shot from age and #3 exhaust guide was dropping into the bore.
Attachment JGuide.jpg not found
Larry C.
- wireman
- Thank you received: 299
07 May 2012 16:35 #520519
by wireman
Replied by wireman on topic loose guides in J Head
Could you ream the holes and use oversized guides to fix it?
- mark1122
- Keep twisting it
- Thank you received: 109
07 May 2012 18:42 #520534
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic loose guides in J Head
i hadnt heard of that before. good to know. what r the options for a remedy?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Kraz1
07 May 2012 18:58 #520541
by Kraz1
Replied by Kraz1 on topic loose guides in J Head
"One Option" Click---->
Valve Guides
- zed1015
- Thank you received: 1561
08 May 2012 07:08 - 08 May 2012 07:09 #520654
by zed1015
Replied by zed1015 on topic loose guides in J Head
APE do o's guides too.
Also a common issue when the guides have been changed a few times.
Last edit: 08 May 2012 07:09 by zed1015.
- LarryC
08 May 2012 07:43 #520660
by LarryC
I keep some +.004's around for this situation. Last one was so bad it needed 2 +.025".
Larry C.
Replied by LarryC on topic loose guides in J Head
wireman wrote: Could you ream the holes and use oversized guides to fix it?
Larry C.
