- Thank you received: 1
needing torque specs
- 79kz1000*
06 May 2012 21:25 #520326
by 79kz1000*
79 kz 1000 ltd
76 kz 900
needing torque specs was created by 79kz1000*
Important needing torque specs for a 79 kz1000 for the head/jug nuts, camshaft caps an order of caps. putting back together. also the connecting rod caps. Any help would b great.
79 kz 1000 ltd
76 kz 900
- 79kz1000*
06 May 2012 21:53 #520337
by 79kz1000*
79 kz 1000 ltd
76 kz 900
Replied by 79kz1000* on topic needing torque specs
Also needing valve clearances??? thanks Matt
79 kz 1000 ltd
76 kz 900
- wireman
- Thank you received: 299
06 May 2012 22:49 #520370
by wireman
Replied by wireman on topic needing torque specs
Connecting rod caps? :blink:
There should be several files downloaded on here by OMR someplace with that info
