base gasket size????
  • 79kz1000*
  • 79kz1000*'s Avatar Topic Author
02 May 2012 17:46 - 03 May 2012 10:11
#519390
Just got my mtc pistons an jugs yesterday. i went to order my gasket kit an they asked what thickness do i want for the base gskt? Is there any suggestion i would start with? motor has never been rebuilt an head was never shaved. any help would b great. bc i have to order no matter what, don't have any.thanks again
79 kz 1000 ltd
76 kz 900
Last edit: 03 May 2012 10:11 by 79kz1000*. Reason: spelling
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: base basket size????
02 May 2012 18:19 - 02 May 2012 18:21
#519400
just use the standard fiber Cometic gasket. its about .020" .
u would use a thicker 1 if u had the jugs or cases decked.
thicker gaskets r made of aluminum, or copper, and r more prone to leaks in a street motor. if they dont have the fiber cometic, get it somewhere else. thinner 1's r used to set the piston at the right height in the bore. its safe to run the piston about .010" down below the deck. if u run a .043" head gasket.u can go less but u need to know what u r doing.
the further down it is , the less compression u end up with, so high is better . but if its too high, u hit the head, then u get a head ach. :pinch:
store.valueweb.com/servlet/starrace/-str...R%2C-KAWASAKI/Detail
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 02 May 2012 18:21 by mark1122.
  • 79kz1000*
02 May 2012 22:40
#519458
Thanks man i appreciate the help. time to order parts an get it running!!!
79 kz 1000 ltd
76 kz 900
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
02 May 2012 22:43
#519460
In your heading,could you change "basket to gasket"? :woohoo:
