- Thank you received: 103
Cams
- roy-b-boy-b
- roy-b-boy-b
- dbsuperbiker
- Thank you received: 17
- roy-b-boy-b
- racer54
- Thank you received: 114
Megacycle lists 2 versions.....470-85 and 470-x15
470-85 .465 lift 270* dur. 108* l/c
470-x15 .465 lift 264* dur. 108*/110* l/c
Cam Motion......Z9 .465 lift 274* dur. at .050 lobe center 110*
- z1kzonly
- Thank you received: 540
So when you just roll the mic or calipers over the lobe to get the highest measurement
does not mean the gross lift. You have to subtract something?
Let the Machine shop Head guys tell you.
Do you have a set of stock cams layin around to compare?
I looked at some stock used cams. there total measurements were about 1.418" -1.420"
across the lobes.
Did the head holding them cams have machined relief clearence spots on top by the lifter buckets?
Was it using shim under buckets?
- APE Jay
- Banned
- Thank you received: 58
- roy-b-boy-b
Thanks racer, I am just trying to nail down who made these cams.
Thanks Jay, I guess I could put all these parts in the lay down frame I have and just look at it and make noise at meets !
It was suppose to be Mike Brusso's bike!
- Thank you received: 2098
roy-b-boy-b wrote: ...head was clearanced...
Converted from shim-over-bucket to shim-under-bucket.
- roy-b-boy-b
I am going to sell the whole package together. Roy
- roy-b-boy-b
- DoubleDub
- Visitor
