- Thank you received: 2
GPZ gasket change ?
- dfinnegan71
30 Apr 2012 23:46 #518942
by dfinnegan71
1981 GPZ 550 mild custom
GPZ gasket change ? was created by dfinnegan71
I have an 81 GPZ550 that is leaking from the tach, head gasket and base gasket. Also from the front sprocket. I don't mind the last one, it's like I bought an expensive auto chain lube system!!
Just a quick question, has anyone changed out their base gasket, and head gasket on their 4 cylinder KZ's while leaving the engine in the frame? Is is possible like with the KZ twin cylinder bikes?
- dfinnegan71
01 May 2012 12:50 #519064
by dfinnegan71
Replied by dfinnegan71 on topic GPZ gasket change ?
Anyone? Somebody? Bueller? Bueller?
- Mcdroid
- Gone Kwackers
- Thank you received: 317
01 May 2012 13:00 #519066
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic GPZ gasket change ?
There is no reason to pull the motor to do what you anticipate. Get the official Kawasaki shop manual for your motorcycle and there will be step-by-step instructions for changing gaskets with the motor left in the frame.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- peter1958
- Banned
- Thank you received: 198
01 May 2012 13:02 #519068
by peter1958
Replied by peter1958 on topic GPZ gasket change ?
The tack drive could be leaking more than you think. Clean the areas up and look again at other leaks before tearing it all apart.
- dfinnegan71
01 May 2012 13:40 #519083
by dfinnegan71
Thanks Mcdroid. And thank you Peter, it's leaking on the back under the carbs on the base gasket. And on left side on the head gasket. But thanks for the advice. There is a dry patch between the tach oil leak and head leak. What about the leak behind the sprocket? Doable without engine removal? Shop manual...,a must have.
