- Thank you received: 3
Cover installation method??
- notaduc
30 Apr 2012 21:00 #518892
by notaduc
1980 (mostly) KZ1000
Cover installation method?? was created by notaduc
Just hoping for a quick survey of favored methods for installing side covers, IE dry, or with some sort of chemical.
Thanks!
Thanks!
- Thank you received: 2098
30 Apr 2012 21:58 - 30 Apr 2012 22:02 #518907
by Patton
Replied by Patton on topic Cover installation method??
New, tight grommets with side covers installed dry.
Example of another method, but more difficult to access and requires raising the seat.
Last edit: 30 Apr 2012 22:02 by Patton.
- notaduc
30 Apr 2012 22:00 #518909
by notaduc
Replied by notaduc on topic Cover installation method??
Hmmmm...
I meant engine covers...
- notaduc
30 Apr 2012 22:01 #518910
by notaduc
stator, clutch, kicker, oil pan, cam cover, these type.
- Thank you received: 2829
30 Apr 2012 22:17 #518918
by 650ed
Replied by 650ed on topic Cover installation method??
Can't say I have experience with the KZ1000, but on the KZ650 the engine covers go on dry except for a couple small spots. The KZ650 Kawasaki service manual shows where to apply sealant. AS an example, when installing the clutch cover, sealant is applied on the 2 spots on the engine where the gasket crosses the seam between the engine castings. Best bet IMO is to consult the manual, it should show where sealant is needed. I followed the book and have no leaks. Ed
- notaduc
30 Apr 2012 22:24 - 30 Apr 2012 22:25 #518921
by notaduc
This photo is from oldkawman, looks like orange case sealant squirting out of all the covers...
Doesnt seem like this should be necessary, but I have also heard of folks using rtv and other things I believe.
First instinct was to just follow the manual, but now Im figuring a census first is a good idea.
Last edit: 30 Apr 2012 22:25 by notaduc.
30 Apr 2012 22:37 #518923
by Patton
Could probably use something like a hitch pin clip to scrape off most of that orange stuff.
30 Apr 2012 23:05 #518933
by 650ed
Yuck! That's a good demo on why you should put gaskets on dry. I have given this matter considerable thought, and made the following observation:
Here’s my view on using sealant; others may disagree. If the idea of putting sealant on a gasket is to prevent a leak, please consider the following. Let’s say you have two metal surfaces, i.e. an engine block and a tensioner housing, and there’s a paper gasket that goes between the two. The purpose of the paper gasket is to prevent oil from leaking between the two metal components. So let’s say you put the gasket in there dry (no sealant at all) and bolt the housing to the block squeezing the gasket between the two. Now consider if you could see that housing/gasket/block joint from inside the engine. You would see metal (the block), the inner edge of the gasket, and metal (the tensioner housing). Now you splash plenty of oil inside that area so the joint is soaked in it. Now looking from inside the engine you see oily metal (block), the oily the inner edge of the gasket, and oily metal (the tensioner housing). If the oil is going to seep between the metal and the gasket will the oil care if it seeps between the block and the gasket or the tensioner housing and the gasket? No, if it is going to leak it can leak on the block side or the housing side of the gasket. So, IF the only way to prevent a leak was to put sealant on the gasket you would need to put it on both sides. Fortunately, the dry paper gasket will not leak on either side, so no sealant is needed. This assumes no one has gouged the metal mating surfaces when trying to remove a gasket that some previous owner has glued on because they didn’t know sealant was not needed. In that case seal may be needed but only on the gouged area. This brings up another point; in the Kawasaki service manual there are a FEW areas where sealant is called for. The best example I can give is two spots on the KZ650 clutch cover gasket. The manual calls for sealant on the two (about 1 inch) spots on the engine side of the clutch cover gasket where the gasket covers the joints between the lower and upper engine castings. This is required because mating surface has a seam at these engine casing joints which the gasket alone may not seal. This may not be obvious to someone doing this job the first time. So my best advice is to always consult the service manual to see if and where sealant is required rather than just gluing the gaskets on and later having to scrape them off. Also, you’ll save money by not needing to replace gaskets as often because the ones put on dry can be more easily reused. The CD recording of this speech is available at the door. Ed
- Powerstroke_fan
- Thank you received: 83
01 May 2012 16:10 #519123
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Cover installation method??
You know if that much gasket maker is sticking out on the outside, most likely theres some on the inside of the engine.Hopefully it dont come loose. If you decide to use selant dont use alot.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- DoubleDub
- Visitor
01 May 2012 16:16 #519127
by DoubleDub
Replied by DoubleDub on topic Cover installation method??
The only place on the 900/1000 I have had to silicone was the stator cover bottom half. But I think the leak was really from the wire grommet - get a new one and you'll probably be able to go dry. Some have stated using copper coat on one side makes it easier to remove and reinstall using the same gasket, but that user is probably also a cheap-ass Nebraskan who doesn't post anymore.... :whistle: :evil:
- OnkelB
- Thank you received: 80
01 May 2012 16:51 - 01 May 2012 16:53 #519138
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic Cover installation method??
Some good advice
here
, that's how I do it.
I also share Dan's views on sealer types, the only sealer I ever let near my engines is ThreeBond (aka Hondabond, Yamabond etc.).
Btw, that pic above... :sick:
Last edit: 01 May 2012 16:53 by OnkelB.
