blowin gas out right side exhaust
- slickjr82
27 Apr 2012 23:27 #518473
by slickjr82
blowin gas out right side exhaust was created by slickjr82
well here i go again found the adj screws on bottom of carbs bike starts fine cyl 1/2 run good but 3/4 are blowing gas out the exhaust kz1000 with 26 mm mikuni carbs screws out 1& 1/4 turn what to do next drivin me crazy
- Thank you received: 2098
28 Apr 2012 00:12 - 28 Apr 2012 00:15 #518475
by Patton
With engine cold, would start it running, let run for a few seconds, and then spray water mist over the exhaust header pipes to determine whether the water sizzles and instantly vaporizes off each pipe.
This test will confirm which cylinders are combusting.
If water beads roll down a pipe (instead of instantly vaporizing), would suspect insufficient combustion in that particular cylinder.
Am thinking that inadequate combustion might be resulting in unburnt fuel mixture being blown out the exhaust.
Replied by Patton on topic blowin gas out right side exhaust
slickjr82 wrote: well here i go again found the adj screws on bottom of carbs bike starts fine cyl 1/2 run good but 3/4 are blowing gas out the exhaust kz1000 with 26 mm mikuni carbs screws out 1& 1/4 turn what to do next drivin me crazy
Last edit: 28 Apr 2012 00:15 by Patton.
