Pressurized oil cap 1980 kz440 ltd
- Jay98
Thanks.
- Thank you received: 2829
Regarding the seller saying "parked a few years ago when it was running" consider the following-
Seller says: "The bike ran great just before I parked it."
Seller thinks but does not say: "The bike ran great just before I parked it 23 years ago in the cess pool out behind the barn where the mud daubers, mice, spiders, and other creatures used it for a nest for 2 decades and before my nephew stole parts off it; removed the head, filled the cylinders with cement, and replaced the head."
- Thank you received: 1656
- Jay98
- Nebr_Rex
- Thank you received: 300
When the 400/440 is running they will blow out the breather(on top of the rockerbox).
This happens when the pistons are on their downward stroke.
And there is nothing wrong with a cargo net,they will hold a 12 pack
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Jay98
- Jay98
Nebr_Rex wrote: What 650ed said,clogged breather.
Could it be clogged because I plugged it thinking it was some wort of vac hose? :whistle: long story.
Jay98 wrote: The cargo net was the previous owners idea of holding the seat down. Dont need to go to the hardware store get any bolts that way. The main thing with this bike is it appears to be leaking out of every gasket. So when pulling it apart to replace all gaskets, anything that would be a good idea to have done in the process? I will be powder coating at least everything but the lower engine case in satin black. It has 24000 registered miles on it.
Hold on. Before you pull anything apart consider the following. You plugged up your breather. This created a situation in which pressure would build up inside the crankcase. This pressure, which would not normally be present, would try to push oil out through the seals and gaskets. That may have been why you had leaks. If mine, I would clean the engine very well, make sure the breather is operating properly, change the oil and filter, and drive the bike. If after driving it a few hundred miles you still find leaks you will be able to identify the source of the leaks. However, you may find that without the unwanted pressure in the crankcase it no longer leaks. 24000 miles is not much on these engines, so unless a previous owner has screwed something up the engine shouldn't be leaking. Ed
- Jay98
So, all the leaks have been there and all gaskets need replaced. I have yet to hear it fire and would like to change the gaskets and the oil before doing so since I want to powder coat most of the engine anyways. This is a project for me, I am in no hurry to get it running, I have another bike for that.
