Oil change question
- GTCpopo
- tito
- Thank you received: 3
- racer54
- Thank you received: 114
- MFolks
- Thank you received: 540
- GTCpopo
- 81KZ550/84GPz750
what little oil is left in the cases, isn't enough to worry aboutGTCpopo wrote: I know how to do all that..... There was just left over oil in he little window and when I took it off a lot more oil came out. But I def understAnd were y'all are coming from. Thank you ima just do that instead
you could just change the oil a little more often, so any left over oil isn't completely bad, if it really bothers you
and since we are on the subject of oil I prefer Dumonde Tech GP4 oil
Thanks, Matt
- Powerstroke_fan
- Thank you received: 83
O No here we go agsin lol The oil war is back.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2829
- 81KZ550/84GPz750
I dont mean to start any debates or oil warsOld Man Rock wrote: :laugh: :laugh: :laugh: Well hell, we haven't had a good debate (which oil, chain size, coil mod (:pinch:) etc...) lately... :whistle:
however the dumonde tech is a not very well known, very good oil
so I like to share the info with people
Thanks, Matt
