- Thank you received: 1
PISTON RING GAP
- man-of-war
26 Apr 2012 21:38 #518288
by man-of-war
PISTON RING GAP was created by man-of-war
My rings for the 84 gpz 1100 will be in tomorrow and I was wondering what would be the gap for standard rings.
Thanks
www.facebook.com/media/set/?set=a.283886...&type=3&l=fb51b11c72
Thanks
- bountyhunter
- Thank you received: 337
27 Apr 2012 03:44 - 27 Apr 2012 03:45 #518349
by bountyhunter
Replied by bountyhunter on topic PISTON RING GAP
Put them in the cylinder and measure the gap. It should be about .003" - .004" per inch of bore diameter.
Last edit: 27 Apr 2012 03:45 by bountyhunter.
- man-of-war
27 Apr 2012 07:48 #518354
by man-of-war
Bountyhunter does this link below apply to a GPZ 1100 ENGINE AS WELL.
Most piston ring manufacturers recommend a minimum end gap of .004 inches times the bore diameter for the top piston compression ring. So for a 4 inch bore, the standard end gap would be .016 inches.
For the 2nd compression ring, the standard end gap recommendation for most stock engines is typically .005 in. x the bore diameter. So for a 4 inch bore, the minimum end gap on the 2nd ring would be .020 inches.
For a modified street performance engine that generates more horsepower and heat, the end gap should be opened up a bit to compensate for increased thermal expansion. The recommendation would be a minimum top compression piston ring end gap of.0045 to .005 inches times the bore diameter. For a 4 inch bore, the ring end gap on the top ring should be increased to .018 to .020 inches.
For the 2nd compression ring on a modified street performance engine, the recommendation is typically open up the end gap to .0055 inches times the bore diameter. For a 4 inch bore, the 2nd ring would be gapped to .022 inches.
For a nitrous or blown racing engine, the top ring end gap sould be opened up to as much as .006 or .007 inches times the bore diameter. Now we're looking at a 2nd ring end gap of .024 to .028 inches in an engine with 4 inch bores.
For the 2nd ring on a nitrous or blown motor, the recommended ring end gap is even wider: .0063 to .0073 inchestimes the bore ( or 0.025 to 0.029 inches with a 4 inch bore).
The recommended ring end gap for oil rings regardless of the engine application is typically .015 inches.
Some racers believe that opening up the 2nd end gap even more (say an additional 10%) can improve overall ring sealing by allowing trapped gases to escape before they blow past the top ring and cause ring flutter at high rpm (say above 5000 to 6000 rpm).
Replied by man-of-war on topic PISTON RING GAP
bountyhunter wrote: Put them in the cylinder and measure the gap. It should be about .003" - .004" per inch of bore diameter.
- bountyhunter
27 Apr 2012 15:27 #518412
by bountyhunter
That's more info than I ever learned about it. When I researched it some time back, the thing I saw many places is simply .003-.004" per inch of bore diameter. Didn't change it for different rings.
- mark1122
- Keep twisting it
- Thank you received: 109
27 Apr 2012 16:59 #518427
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic PISTON RING GAP
heres a good read. this is how i set mine up.
www.hastingsmfg.com/ServiceTips/ring_gaps.htm
the rings u bought should have a spec.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- man-of-war
27 Apr 2012 22:27 #518470
by man-of-war
I did some measuring and the rings are good to go right out of the box.The inside dimiter is 2.84'' x .004'' = .011 ring gap I used .012''
www.facebook.com/media/set/?set=a.290702...&type=3&l=b2b34d3a6d
- man-of-war
29 Apr 2012 12:10 #518633
by man-of-war
are these numbers from the book correct??
www.facebook.com/media/set/?set=a.291852...&type=1&l=e39e0c2749
