Engine "jumps" in the middle of heavy acceleration
Re: Engine "jumps" in the middle of heavy acceleration
26 Apr 2012 23:48
#518325
Perhaps of interest --
Click > www.z1enterprises.com/catalog.aspx?pid=KZ1000-B3-1979-MP0
Good Fortune! :)
  • brianrae33
  • brianrae33's Avatar
27 Apr 2012 13:08
#518398
mine did the exact same thing..it was a worn shift drum grove...can check the drum and forks without splitting the cases
1982 kz1000ltd
  • martin_csr
  • martin_csr's Avatar
Re: -
27 Apr 2012 14:39 - 21 Feb 2013 15:16
#518406
Last edit: 21 Feb 2013 15:16 by martin_csr.
  • toadson
  • toadson's Avatar Topic Author
24 May 2012 23:26
#524625
Thought I would provide an update to this thread. After tightening the chain and doing a carb sync, I haven't been able to replicate this anymore. It has been warmer out, so maybe the warm weather has my bike running better and that was the problem. Or maybe the carbs were causing the problem. I don't think it could have been the chain jumping, but I am ordering a 530 chain and sprockets once I decide on the gearing. SO honestly I don't know what the deal wass, but synching the carbs seemed to give me some more low end power. I actually broke the tire loose on the highway taking off, which I don't think I have ever done on this bike!
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
  • fivestring
  • fivestring's Avatar
06 Jul 2012 13:10
#534256
Is there any info around here on removing and replacing the 2nd gear dogs? I think I may be having the same jumping issue in 2nd under acceleration and wanted to get some education on what it involves.
It might be time to buy a repair manual. :whistle:
4 out of 3 people have trouble with math
Current
1978 KZ1000A2A, hardtailed, bobbed and stretched
my build thread
1977 Yamaha XS750 (parting out)
1978 Honda CB750 Four
1981 Yamaha XS650
1982 Yamaha XS650
Former
1980 Kawasaki CSR750
1980 Suzuki GS850L
1982 Suzuki GS1100K
1987 Suzuki GSXR1100
1985...
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
06 Jul 2012 18:04
#534300
To replace the second gear you will have to completely tear the engine apart. It would probally be easier to just buy another whole tranny that is already backcut or get a good one and have it backcut. But i would make sure you have tried everything else first to eliminate all the easier possibiltys.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • P21
  • P21's Avatar
06 Jul 2012 19:18
#534323
Attachment sprocket.jpg not found
the sprocket looks like it has chiped teeth.
the front cant look any better,
its time a full set of sprockets and chain
Kawasaki KZ 1000 Police (2002) P21
