Random shutoff at idle
- GTCpopo
24 Apr 2012 21:10 #517873
by GTCpopo
Random shutoff at idle was created by GTCpopo
I have a 77 kz1000. The bike has been running great since I did the liner kit for the tank due to debris. But I will be riding the bike and when I come to a light it will drop in rpm and start to die unles I give a blip of gas on he throttle. It will only do this sometimes, I just don't understand why it doesnt do it all the time. Also it wil..... I don't know if it's knocking or what its a weird noise but it runs good at high speeds no knocking noise only when it's about to die out.
Any answers? Much appreciated
- MFolks
- Thank you received: 540
24 Apr 2012 21:21 #517876
by MFolks
Replied by MFolks on topic Random shutoff at idle
Fresh sparkplugs? Checked compresion? Stock ignition & coils? The sparkplug caps have a 5000 ohm resistor that can fail/become intermittent. If it were me, I'd get new sparkplug caps, and before installing them, cut back about 1/4" of the sparkplug wires.
The following user(s) said Thank You: GTCpopo
- Thank you received: 2098
24 Apr 2012 21:35 #517882
by Patton
Replied by Patton on topic Random shutoff at idle
If not already done, would assure valve clearances are within specs.
And this is important to do regardless of compression test results which might be peachy-keen.
- Thank you received: 2829
24 Apr 2012 22:00 #517891
by 650ed
Replied by 650ed on topic Random shutoff at idle
How old is the battery?
- Kawickrice
- Thank you received: 18
24 Apr 2012 22:30 #517899
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Random shutoff at idle
What are the normal rpm's you have it set at. Does it do it all times when idling or just after you have been riding it. Could be some debris left in the idle circuits. A tank of Seafoam might help too.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- baldy110
- Thank you received: 512
24 Apr 2012 23:08 #517914
by baldy110
Replied by baldy110 on topic Random shutoff at idle
Sounds like a vacume leak
- DiamondSkyBlue1000
- Thank you received: 40
25 Apr 2012 00:16 #517929
by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic Random shutoff at idle
Could be the glue that was used to put the handlebar grips on.
Just kidding. The knocking you hear sounds like when the engine is running with carbs that are out of synch. At really low engine speeds this is most pronounced. Why are they out of synch? Well...
Best to go through everything to ensure you are starting from a good baseline.
Make sure your carbs don't have any vacuum leaks, make sure your fuel filters are clean, pull your float bowls and make sure they are clean, etc. Drop your petcock (that just sounds weird) and clean out the screen. Pull your plugs and check them. Synch the carbs. You know, give it a good going over, maybe even a full tune up.
- cameronkawasaki
25 Apr 2012 23:00 #518106
by cameronkawasaki
1979 KZ750B-4
Replied by cameronkawasaki on topic Random shutoff at idle
Take out your carbs and locate your pilot jets (usually in the float bowl) and make sure they don't have any debris in them.
1979 KZ750B-4
- bountyhunter
- Thank you received: 337
26 Apr 2012 01:20 #518142
by bountyhunter
Replied by bountyhunter on topic Random shutoff at idle
Maybe crud getting into a pilot jet. Have inline filters?
- GTCpopo
26 Apr 2012 12:24 #518201
by GTCpopo
Replied by GTCpopo on topic Random shutoff at idle
I have taken the carbs apart 15 times because they kept pouring gas out of the overflow due to shit in the tank. After I put a tank liner everything stopped leaking so that was good. The carbs are so clean you could eat off of them. I don't understand how you mean synch the carbs? Is the knocking noise from the carbs or the motor because I don't hear it unless I'm not idling or low low idle about to die. Is this problem going to ruin my bike if I don't get fixed immediately because it runs fine otherwise?
26 Apr 2012 15:46 - 26 Apr 2012 15:57 #518223
by Patton
Most all these bikes will emit the death rattle just before dying from too low rpm. Sounds like the engine is "digesting nails."
Even with otherwise perfect carbs, receiving adequate delivery of clean fresh gasoline -- a good strong steady idle at 1000~1200 rpm usually requires close carb sync and finely tuned pilot mixture adjustments.
Even with otherwise perfect carbs, receiving adequate delivery of clean fresh gasoline -- Noisy rough idle at 1000~1200 rpm is often attributable to poor carb sync and/or improperly tuned pilot mixtures.
When each cylinder is operating at a different level of efficiency at idle rpm, the unequal power strokes result in herky-jerky cam chain activity (which is noisy) and generally rough unsteady idle.
Carb sync, together with pilot circuit tuning, serve to equalize the power output of each cylinder at idle rpm, which contributes to a smoother running engine, especially at lower rpm.
Last edit: 26 Apr 2012 15:57 by Patton.
- bountyhunter
26 Apr 2012 15:51 #518224
by bountyhunter
check fuel levels in bowls with clear tube. If it's off even a little, it won't idle right.
On mine, rough idle was from timing advancer screwing up.
