KZ900 Front Sprocket Lockwasher
  • CasinovaRock23
  • CasinovaRock23's Avatar Topic Author
23 Apr 2012 14:24
#517572
I'm putting new sprockets on my '76 KZ900 and I found that the worn-out sprocket did not have a pin hole for the lock-washer. The sprocket I bought, however, does have the hole but did not come with a washer. I would like to find the right washer to install. Does anyone know where I can buy this specific washer?
Thanks,
-Charles
Re: KZ900 Front Sprocket Lockwasher
23 Apr 2012 14:42
#517579
It is still an active part (part #92024-044) so any Kawasaki dealer will have it or can order it.
  • bountyhunter
  • bountyhunter's Avatar
23 Apr 2012 16:00
#517583
Kawi stopped using the crappy washer with the little pin and went to one with splines that fit the shaft which you flatten over onto the edge of the nut. Mine originally came with the "pin" kind but when I needed a replacement, the dealer sold me the "flatten over" kind. They better because some of the new sprockets do not come with the drilled hole for the pin to fit into.
  • moneypit
  • moneypit's Avatar
23 Apr 2012 18:06
#517603
2-76 kz900
St Paul MN
  • CasinovaRock23
25 Apr 2012 16:33
#518033
Thanks all for the info/link. I had searched z1enterprises.com before but I guess I did a poor job of it.
Hopefully I'll have the whole drive train and rear wheel reassembled before next week! Front brakes are next...
-Charles
