interchange help
- devo
22 Apr 2012 18:01 #517371
by devo
Hellspawn
interchange help was created by devo
I have an 1982kz1100 A - Can get a 1983 kz1100ltd will the 83 swap in?
Hellspawn
- spark23ca
- Thank you received: 2
22 Apr 2012 18:23 #517372
by spark23ca
1982 kz 1000 ltd ..someone started to make a bobber out of it and realized it didnt' run and they didn't know how to run their wrenches
Replied by spark23ca on topic interchange help
i would imagine they are the same ...check the parts where the motor supports and bolts go threw the frame and motor such as crank cases and stuff on bikebandit to see if they have the same part numbers...
- Thank you received: 1656
23 Apr 2012 10:50 - 21 Feb 2013 15:11 #517533
by martin_csr
Last edit: 21 Feb 2013 15:11 by martin_csr.
- devo
23 Apr 2012 13:43 #517567
by devo
Hellspawn
Replied by devo on topic interchange help
Both are shaft having tuff time track down see if the 1983 will jolt in
Hellspawn
23 Apr 2012 14:11 - 21 Feb 2013 15:11 #517570
by martin_csr
The following user(s) said Thank You: devo
- devo
23 Apr 2012 14:40 #517577
by devo
Hellspawn
Huge thank you on site and the research great help
Hellspawn
