How bad is this?
- MFolks
Re: How bad is this?
22 Apr 2012 20:30
Some places to look:
www.redlinecycle.com has some new and used engine cases.
www.sudco.com
www.reproductiondecals
www.johnnysvintagemotorcycle.com
www.sudco.com
- saxonpirate
- 1983 KZ1100 LTD
22 Apr 2012 20:32Mark Wing wrote: I've fixed my cases with damage almost the same as that by cleaning the area real good and using part of a soda can taped on the inside and just filled it in with J-B Weld. It's held for years.
Mark
Totally agree Mark. Anything is possible if you think outside the box, are resourceful enough and have the requisite skills. The trouble is on forums you can give advice as to how a repair can be made, knowing that "you" could carry it out, but not knowing if the recipient has the same skills and knowledge base as yourself.
1983 KZ1100 LTD..
Ride like your life depended on it
- MFolks
22 Apr 2012 20:42
- DiamondSkyBlue1000
- 0Z.Z1R Mk2
23 Apr 2012 01:29 - 23 Apr 2012 01:32MFolks wrote: Look here:
www.z1parts.net/product/z1-900-kz900-kz1...ht-side-engine-cover
It's the engine case that's broken MFolks...not the side cover...
"edit" Didn't see your above post....
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
Last edit: 23 Apr 2012 01:32 by 0Z.Z1R Mk2.
- Bigo334
23 Apr 2012 05:36 - 23 Apr 2012 05:38
Last edit: 23 Apr 2012 05:38 by DiamondSkyBlue1000.
23 Apr 2012 05:51 - 23 Apr 2012 05:59
Oh, now I see it. I was looking at the large cover that goes behind your, uh, opening.
Maybe you can replace the ignition cover and put a screen over the hole and say it's a vent for your ignition until you can get it fixed.
Last edit: 23 Apr 2012 05:59 by DiamondSkyBlue1000.
- baldy110
23 Apr 2012 14:40
I'm with Mark Wing on this. That area is not structual and can be repaired with JB weld using the method Mark told you. I have had JB weld repairs last a very long time as long as the area isrepped correctly and made very CLEAN.
