- Thank you received: 7
oil pressure
- nobody
20 Apr 2012 23:11 #517005
by nobody
oil pressure was created by nobody
hi to all one quick question i have a 1982 kz1100 spectra. what i would like to know is what kind of oil pressure should i have .i know a lot of variables just in general.want to buy a gauge.thanks
- Motor Head
- Thank you received: 391
20 Apr 2012 23:36 #517018
by Motor Head
Replied by Motor Head on topic oil pressure
You need a low pressure gauge, as the oil pressure will be low compared to a conventional engine. About 3psi hot, so a gauge that goes from 0-10 or 15 psi would be required.
- MFolks
- Thank you received: 540
20 Apr 2012 23:37 #517019
by MFolks
Replied by MFolks on topic oil pressure
The bigger 4's oil pressure will be between 2.2 and 2.8 PSI, as they have roller bearing crankshafts(Z-1's Kz900's,Kz1000's and Kz1100's)
- rstnick
- Thank you received: 377
20 Apr 2012 23:37 #517020
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic oil pressure
If I'm not mistaken, it's only 6 psi.
Someone please confirm this.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- nobody
21 Apr 2012 02:42 #517049
by nobody
Replied by nobody on topic oil pressure
thanks thats what i :blush: needed to know
- mark1122
- Keep twisting it
- Thank you received: 109
21 Apr 2012 09:54 #517064
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic oil pressure
2.8psi at 3000 is right i believe. i had a couple of gauges years ago. i found that the pressure would be hi when cold, and if i revved it too hard the gauge would brake and no longer function. so make sure it is warmed up well before u gas it hard.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
