All apart, now what....
- BB
19 Apr 2012 11:54 #516657
by BB
1980 KZ1000P - The Mistress
2002 R1150GS - Matilda
All apart, now what.... was created by BB
Hi Guys,
I am doing a complete rebild of a 1980 KZ1000P. She has 36,000 miles on her, hasnt run in a while. I though I would pull the engine all the way down since I was going this far. Internals all look good, everything so far is within spec, very little wear. I know the cops beat on these bikes, but they were maintained to the book also.
I plan to replace the cam chain and all gears, new rings, gaskets etc.
My question is now that I have it all apart, are there any other parts I should look at/replace?
Thanks for the help, photos below.
Attachment IMG_0207.JPG not found
Attachment IMG_0214.JPG not found
Attachment IMG_0226_2012-04-19.JPG not found
Attachment IMG_0227.JPG not found
Attachment IMG_0237.JPG not found
Attachment IMG_0247_2012-04-19.JPG not found
Attachment IMG_0246.JPG not found
- LarryC
19 Apr 2012 20:37 - 19 Apr 2012 20:39 #516742
by LarryC
Larry C.
Replied by LarryC on topic All apart, now what....
Smart Move
Replace all the ancient cam sprocket idlers with Liska idlers along with that new cam chain.
Not much carbon build up for all those miles. Measure up your bores and pistons. You might just get by with a ball hone and new rings.
Larry C.
Last edit: 19 Apr 2012 20:39 by LarryC.
- Chaotic Reason
- Thank you received: 15
19 Apr 2012 21:16 #516760
by Chaotic Reason
Michael
1980 KZ1000 shaft drive
Replied by Chaotic Reason on topic All apart, now what....
I'd do the shift shaft seal, and all the oil-rings (oil pump, internal oil passageway, oil filter cover and oil filter), tach drive seal, and valve stem seats. May I also assume that you'll be cleaning the head and lapping the valves? You might want to check your valve guides for any play in them. Just my 2 cents.
Good luck.
Good luck.
Michael
- TomW
- Keep the blue side up.
- Thank you received: 52
20 Apr 2012 13:27 #516900
by TomW
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
Replied by TomW on topic All apart, now what....
For sure what everyone else said, plus clean and overhaul the carbs, install APE cylinder studs, check the clutch discs for wear, replace if worn beyond 1/2 the service life, replace all the oil seals and use Viton valve seals, pull the rotor and look at the starter clutch, replace the springs and pins if worn. I've got a once used ball hone I'll lend you to do your cylinders. PM me on that. Polish the cases while you have it apart. Make it look as good as it runs.
- BB
23 Apr 2012 17:27 #517598
by BB
Replied by BB on topic All apart, now what....
Awesome tips guys, thanks for the advice. I am pretty mechanically minded but this is my first project. Forgive my ignorance but please explain the ball hone process?
TomW - she is all at the powdercoaters, he is blasting everything clean for me and applying a clear wet paint to the engine, powdercoating everything else - she should look beautiful. I cant wait to get the pieces bacj and start assembly.
thanks again for the tips, if I am this deep I dont want to skimp now. Can I get rid of the valve cover tops with the hose connector? Seems like I could just put in plain covers?
- Thank you received: 2829
23 Apr 2012 17:40 - 23 Apr 2012 17:42 #517599
by 650ed
Replied by 650ed on topic All apart, now what....
A ball hone isn't as painful as the name sounds. :ohmy: Here's an example:
Last edit: 23 Apr 2012 17:42 by 650ed.
