PLEASE HELP! Valve cover oil leak...
- KzChop82
18 Apr 2012 21:17 #516558
by KzChop82
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
PLEASE HELP! Valve cover oil leak... was created by KzChop82
Thanks for viewing this-
This is a 1982 kz1000m2csr engine. About 600 miles, runs fantastic, but it has not been run consistently in about 30 years. After about 50 miles of riding I noticed that I was getting a very slow leak by the valve cover. I can't tell if it is from that large jug nut, or from underneath the valve cover gasket.
Has anyone ever had this problem before, is it common?
What should I do to fix it?
Thanks in advance for your thoughts.
Clinton, NJ
- P21
- Thank you received: 34
18 Apr 2012 22:07 #516574
by P21
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic PLEASE HELP! Valve cover oil leak...
looks like the end plugs to me
give her a good cleaning and see where it starts to leak
- Kawickrice
- Thank you received: 18
18 Apr 2012 22:52 #516588
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic PLEASE HELP! Valve cover oil leak...
Yep end plugs. Get a valve a cover gasket with new end plugs and it will be fixed
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Thank you received: 2098
18 Apr 2012 23:21 #516590
by Patton
Replied by Patton on topic PLEASE HELP! Valve cover oil leak...
Are the cam/valve cover bolts torqued to specs?
Is the oil seepage confined to this particular area?
- KzChop82
19 Apr 2012 07:04 #516613
by KzChop82
Clinton, NJ
Replied by KzChop82 on topic PLEASE HELP! Valve cover oil leak...
Thank you to all that have read, and also that have replied.
Patton, I assume your taking about the large chrome bolt heads? Do you know the torque amount off hand?
Thank you.
Thank you.
Clinton, NJ
19 Apr 2012 09:12 - 19 Apr 2012 09:27 #516628
by Patton
Nope, not the large chrome head bolts.
Meaning the 16~20 bolts that attach the cam cover (aka valve cover) to the head.
The oil seepage might be through the gasket situated underneath the cover.
Would clean the engine, allow it to thoroughly dry, spray foot powder onto suspected leak areas (all over edges of the cam cover and head gaskets, around the tach drive and exhaust clamps, etc.). It should then look like a clean white blanket of freshly fallen snow. :lol:
Start the engine, and watch for appearance of darkening area where the oil is coming through the powder.
The source of leak is usually very evident.
Lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
KzChop82 wrote: ... the large chrome bolt heads?....
Last edit: 19 Apr 2012 09:27 by Patton.
- bountyhunter
- Thank you received: 337
19 Apr 2012 15:12 #516686
by bountyhunter
Replied by bountyhunter on topic PLEASE HELP! Valve cover oil leak...
The small valve cover bolts are spec'd at about 100 INCH-pounds, but I think that's too high. I think maybe 60 - 70 Inch pounds is enough. I torque them with a short 10mm wrench and go by feel.KzChop82 wrote: Thank you to all that have read, and also that have replied.
Thank you.
- KzChop82
19 Apr 2012 19:55 #516729
by KzChop82
Clinton, NJ
To all that have replied- thanks much for your help. I think it is amazing as to how fast some of the responses came in. If you all are anything like me- when there is an issue with my bike, I think about it constantly. It's sort of consuming. You put so much time and effort into a project like this- I like to solve problems ASAP.
Great forum and members.
Clinton, NJ
