1980 KZ550A-Best Engine oil to use?
- TexasBoot
16 Apr 2012 23:56 #516267
by TexasBoot
1980 550 Kawasaki
1980 KZ550A-Best Engine oil to use? was created by TexasBoot
Yes I was told to use a 20-50wt for my 1980 KZ550A Kawasaki. I was woundering how true is this and will that be good for my engine? Its the origenal engine for what I was told when I bought the bike.
1980 550 Kawasaki
- RonKZ650
- Thank you received: 240
17 Apr 2012 00:05 #516269
by RonKZ650
Replied by RonKZ650 on topic 1980 KZ550A-Best Engine oil to use?
Oil recommendations usually run into a war on most newsgroups as it's a very personal preference thing. 20W50 is a good oil grade for hot weather riding. No good below about 50 degrees as too thick. Thousands of guys use 15W40 Rotella, Delo, or any of the other similar diesel spec oils with good results, but 15W40 too thick for cold weather too. 10W40 was original recommended grade. You really can't go wrong running 10W40 as recommended. Don't use car spec oil, get motorcycle oil. There is a difference.
The following user(s) said Thank You: TexasBoot
- TexasBoot
17 Apr 2012 00:22 #516273
by TexasBoot
1980 550 Kawasaki
Replied by TexasBoot on topic 1980 KZ550A-Best Engine oil to use?
Thanx I did not know that there was a difference between car and motorcycle oil. Damn you think my dad would of told me that. Hes been riding his harley since the 70s. Plus he know this is my first build and that Im basiclly learning as I go. But I have the book so no worries here! lol
1980 550 Kawasaki
- MFolks
- Thank you received: 540
17 Apr 2012 00:29 #516276
by MFolks
Replied by MFolks on topic 1980 KZ550A-Best Engine oil to use?
I could be wrong, but I believe harley's do not have a wet plate clutch like the Kawasaki's have, where engine oil is shared with the transmission.
Engine oil : The commercial grade oils are clearly superior to the mass market oils. For the best protection in your bike or car, use Shell Rotella Synthetic, available at Wal-Mart in blue containers . For the best petroleum oil you can buy, get Shell Rotella T, Mobil Delvac 1300, or Chevron Delo 400, available at any auto parts store. On the back of most oil cans is a circular stamp with the certification. Avoid oils that say "energy conserving" in the bottom half of the donut.
These oils contain friction modifier additives that could cause clutch slipping over time. The EPA mandated certain gas mileage, so the auto makers turned to the oil manufacturers who came up with friction modifiers of the oil to meet these new standards. All XXw-20 and XXw-30 oils are energy conserving, and should not be used in your motorcycle. Don't buy any oil additives like STP or Slick-50.
- Thank you received: 2098
17 Apr 2012 00:34 #516278
by Patton
Replied by Patton on topic 1980 KZ550A-Best Engine oil to use?
The shear factor reportedly shortens oil life when the same oil supply is shared to lubricate both the transmission and the engine.
- LarryC
17 Apr 2012 01:43 #516285
by LarryC
Larry C.
Replied by LarryC on topic 1980 KZ550A-Best Engine oil to use?
Those little engines were tough and reliable. Oil's come a ways since 1980. You can run the 20/50 in really hot weather but you don't need to. Main thing with oil, is regular changes with a filter. There are lots of good oils out there to choose from.
Larry C.
- harm
- Tom
- Thank you received: 13
17 Apr 2012 13:32 #516338
by harm
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Replied by harm on topic 1980 KZ550A-Best Engine oil to use?
I run 20/50 in mine and when i run something thinner the trans doesn't shift as nice
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
