Oil leaking from throttle cable?
  • ldizzle
  • ldizzle's Avatar Topic Author
15 Apr 2012 19:41
#515991
hey what's up KZ. What a wealth of knowledge these boards have been.
I have been working pretty continuously on an 1982 750ltd rebuild.
After changing some orings, gaskets, and some minor tuneups- I'm stumped by a strange oil leak!
It is coming, from what appears to be the throttle cable insert. The leak is then dripping down the block onto the headers down to the ground.
Again, I am perplexed...Is there an o-ring back there?
Thanks for any help!
  • TexasKZ
  • TexasKZ's Avatar
Re: Oil leaking from throttle cable?
15 Apr 2012 19:46
#515993
That, my friend, is a tachometer cable. Yes, there is an o-ring and they do deteriorate and leak. fortunately, they are cheap and easy to replace.
  • DFIGPZ
  • DFIGPZ's Avatar
15 Apr 2012 19:46
#515994
That's the tachometer cable common place for a oil leak call z1 enterprises you need seal, oring and gasket. they will fix you up.
1984 750 Turbo
  • DoubleDub
  • DoubleDub's Avatar
15 Apr 2012 20:05
#516002
  • ldizzle
30 Apr 2012 20:30
#518888
Just got it all fixed up! after 20 mins of riding... I think I'm just seeing residual dripping.
THe oil seal was completely gone. No good. And the 0-ring was flat as well.
My 750LTD only had the ring for one(1) O-ring though!
