- Thank you received: 5
Can i use stock cam gears?
- jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
- mark1122
- Keep twisting it
- Thank you received: 109
it is normal to degree an aftermarket set of cams, as they can run at dif timing specs, than the stock cams.
since u r building motors , it would be beneficial to learn how to do this. it is not difficult but u will need a few special tools.
OMR has a tutorial on it.
Look up
MOTORCYCLE CAM DEGREEING FOR ZOMBIES
In the file base
kzrider.com/filebase/cat_view/231-not-model-specific?start=40
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- notaduc
- Thank you received: 3
The cams will be a waste of money without degreeing them properly... Adjustable cam gears are only eighty bucks or something, I would absolutely get them.
1980 (mostly) KZ1000
- andy9802gt
notaduc wrote: Absolutely need, no, not really, the bike will run.
So if it's not absolutely needed are you going to pony up for the new valves he's gonna need when they crash into the pistons and each other? The occurrence of damage is almost garuanteed if you don't degree those cams.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- jordan
andy9802gt wrote: You absolutely need to degree the cams which is impossible without adjustable cam sprockets, either homemade or bought. I run the exact same setup as carbs, cams, and pistons as this except I have I built head, those carbs are entirely to much for a stock head in my humble opinion. Expect all sorts of rideability issues with them since I don't think you'll be able to detune them enough to run well on a stock head or one even remotely close to stock.
The 34mm flatslides have been on the bike for two seasons with all bone stock internals and they really woke the bike up. Runs great, idles great, and throttle response is outstanding. They will do just fine on this mild setup. I will have him purchase the sprockets. 80 dollars is nothing at this point in the build. Thank you everybody for your opinions and information
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- notaduc
Ok, I take it back. Jus' get the gears.
- roy-b-boy-b
- Thank you received: 103
