- Thank you received: 2
Cam Chain Dampners
- lemo32
- The Price of Cool aint cheap
14 Apr 2012 11:06 #515746
by lemo32
1979 kz 1000 06 katana 750
Cam Chain Dampners was created by lemo32
Is the little black rubber dampners that ride on the cam chain wheels suppose to be hard as a rock, or are they soft when new? also would anybody know if cam chain guide has soft rubber on the end?
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
14 Apr 2012 11:11 #515748
by BlackZ1R
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
Replied by BlackZ1R on topic Cam Chain Dampners
soft. I have a whole bag of GOLD(soft rubber) parts ready for my Z1-R
Kawasaki
- Powerstroke_fan
- Thank you received: 83
14 Apr 2012 11:11 #515749
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Cam Chain Dampners
I believe the small dampers are suspose to be soft when new.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- RonKZ650
- Thank you received: 240
14 Apr 2012 11:40 #515752
by RonKZ650
Replied by RonKZ650 on topic Cam Chain Dampners
They were soft when new, hard after 6 months use. So if you replace them now, by next fall they will all be hard again so might as well just reuse the old hard ones. Now, if there are other pieces available that don't turn to rock hard right away then by all means use them. I've never tried any but factory Kawasaki. They started using the dampers in late 1977 I believe, before that they just used solid steel shafts. The dampers were supposed to quiet down the engine. No big deal if they are hard, at worst case you are right where the engine was pre 1977 and that was just fine before they added them to the design.
- lemo32
14 Apr 2012 11:44 #515753
by lemo32
Replied by lemo32 on topic Cam Chain Dampners
Good to know, the ones i have a hard as rock, but thinking about it I guess with the heat they woud all cook eventuaully. Money saved is money earned.
- mark1122
- Keep twisting it
- Thank you received: 109
14 Apr 2012 13:38 #515770
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Cam Chain Dampners
yes u r right. the heat hardens them. in time they get brittle crack and fall apart.
Liska, makes rollers with steel centers.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
